ᐅ What should I keep in mind when cleaning the Ikea BRIMNES furniture?
Created on: 20 Dec 2019 10:03
SERONNY37
SERONNY37
20 Dec 2019 10:03
Hello everyone, I recently purchased the Ikea Brimnes furniture system, especially the bed and a chest of drawers. Before using them for the first time, I would like to find out about the correct cleaning methods. My specific question is: What should I keep in mind when cleaning Ikea BRIMNES to properly care for the surface and material without risking damage? Are there any cleaning products to avoid, and what is the best way to deal with stains or dust? I would appreciate any detailed instructions and practical everyday tips.
KINMIN4
20 Dec 2019 10:17
For cleaning BRIMNES, it is usually sufficient to wipe the surfaces with a damp cloth. Do not use abrasive substances or harsh cleaners, as the material is coated and could be damaged.
tangi
20 Dec 2019 10:45
Basically, you should pay attention to the furniture material with BRIMNES. Most surfaces are melamine-coated, which makes them durable but sensitive to solvents and abrasive cleaners. I recommend using a mild soap solution and a soft, damp cloth. It’s best to remove stains immediately because dried substances are harder to clean and scrubbing too hard can scratch the surface.
SERONNY37
20 Dec 2019 11:22
tangi schrieb:
It is best to remove stains immediately, as dried substances are more difficult to remove
Thanks for the tip, that’s important. Can water stains or grease deposits on the edges be wiped off easily with a microfiber cloth, or should a different method be used? Are there any specific care products that Ikea recommends for BRIMNES?
barEsperan
20 Dec 2019 12:01
Water stains or grease can be effectively removed with a mixture of neutral dish soap and water. Do not use alcohol-based or solvent-containing cleaners, as they can damage the surface.
KUDAISY
20 Dec 2019 12:47
For cleaning the Ikea BRIMNES, I recommend the following procedure:
- First, remove dust with a dry, soft cloth.
- Then wipe the surfaces with a damp microfiber cloth and a mild soapy solution.
- For stubborn stains, gently assist mechanically without rubbing.
- Special furniture oils or waxes are not necessary, as the surface is lacquered or melamine-coated.
- Avoid abrasive cleaners, bleach, and harsh household cleaning agents.
A common mistake is using overly strong cleaning substances that damage the protective layer and make the surface porous.
