ᐅ How do I properly remove dust from IKEA BRIMNES furniture?
Created on: 15 May 2022 08:13
Tokopau
Hello everyone, I have a specific question regarding the cleaning of my IKEA Brimnes furniture. Specifically, I want to know how to dust these pieces properly without damaging the surfaces or leaving unwanted residues. The BRIMNES series is mostly made of laminated wood-based panels, so I’m unsure which cleaning agents and methods are best suited. I would like to know which cleaning products I can use, which tools are optimal, and how often it is ideal to dust in order to maintain both the appearance and the durability of the furniture. I appreciate any tips, advice, and experiences!
Tokopau
16 May 2022 08:44
Thank you for the previous answers. Another question: How do you deal with the smooth, white surfaces of the Brimnes series, which are particularly prone to visible streaks or water marks? Are there any tips for achieving streak-free results after cleaning these surfaces with a damp cloth, or is it better to try to prevent these marks from forming in the first place?
bapar
16 May 2022 10:11
For white, smooth surfaces, it is important to avoid leaving any liquid standing. The proper method is to follow up damp wiping with a dry, soft cloth to remove any remaining moisture or cleaning product residues.
I recommend thoroughly wringing out the microfiber cloth used, as excess moisture can quickly cause unsightly water spots or streaks. Additionally, dirt and grease often accumulate along edges and handle areas, making stains more visible – in these cases, work patiently and gently without stressing the surface film mechanically.
Furthermore, I advise using cleaning agents in very small amounts, perhaps just a few drops of a mild dishwashing detergent, to prevent residue buildup.
Another tip: using a soft cleaning sponge without an abrasive core or a lint-free cotton cloth can help avoid streaks.
Repar
16 May 2022 12:39
After mopping, be sure to buff the surface with a dry microfiber cloth. This will remove any streaks. Do not apply pressure to the surface and avoid using abrasive cleaners.
Tokopau
17 May 2022 09:52
Gafiel schrieb:
For very stubborn stains, you can also use a mild dish soap solution – but only sparingly and wipe off immediately with a dry cloth.
That sounds very reasonable – do you have any specific recommendations for dish soaps that work particularly well, or is it better to just stick to as neutral products as possible? I want to avoid unnecessary use of harsh chemicals, but I often have the problem that my usual cleaners seem to slightly damage the film.
Benge5
17 May 2022 11:16
Neutral, pH-balanced dishwashing detergents are the best choice for BRIMNES furniture. Usually, simple, fragrance-free varieties from the supermarket are ideal, as they do not contain additives that could damage the laminate surface. Natural-based cleaners can also be used, provided they do not contain essential oils or solvents. It is important to use the detergent very sparingly and to thoroughly wipe the surface with a damp cloth afterward. Then, dry immediately to avoid any residue.
TARAON
17 May 2022 13:04
To wrap up the topic with a wink: If you love BRIMNES furniture, you should treat it like a sensitive VIP guest – meaning no wet beer, no harsh substances, but rather a gentle “dusting ballet.”
Jokes aside, regular but careful cleaning is key. A little extra care with a nurturing routine can make a big difference.
