ᐅ How can I clean Malm furniture without leaving any harmful residues?
Created on: 4 Apr 2023 09:17
markno
markno
4 Apr 2023 09:17
Hello everyone, I have some furniture from the Malm series by IKEA at home and would like to clean it properly without leaving any negative residues or damage. My question is: What is the best way to clean Malm furniture without causing streaks, film residues, or discoloration on the surface? I would like to know which cleaning products are suitable, whether to use damp or dry cloths, and if certain substances should be avoided on the surface. It is also important for me to understand if there are differences depending on the surface finishes of Malm (e.g., lacquered, coated) that I should take into account. Thanks for any tips and experiences!
gauvin37
4 Apr 2023 09:44
It is best to use a damp microfiber cloth without any cleaning agents. Only for heavier dirt, you can mix mild dish soap with water. Absolutely avoid using abrasive cleaners or harsh chemicals.
Dilen
4 Apr 2023 10:22
Basically, it is important to differentiate the surface of Malm furniture depending on the finish. Many Malm dressers have a melamine or foil coating, which can be sensitive to aggressive cleaners and abrasive cloths. Therefore, I recommend starting with a damp microfiber cloth using lukewarm water. If that is not enough, a drop of neutral, pH-balanced dish soap can be added. Cleaning should always be done gently, avoiding vigorous scrubbing motions.
Also important: after cleaning, surfaces should be wiped dry to prevent water spots. Personally, I advise against using cleaners containing alcohol or ammonia, as they can roughen or discolor the surface. Have you already checked whether your Malm furniture has a lacquered or melamine-coated surface? That would be an important detail.
markno
4 Apr 2023 10:38
Dilen schrieb:
Have you already checked whether your Malm furniture has a painted or melamine-coated surface?
Good question, I looked into it: The surfaces usually feel rather matte and smooth, so I suspect they are melamine coatings rather than painted wood finishes.
Unfortunately, when cleaning with a regular all-purpose cleaner, I noticed that a slight film forms after drying, which is difficult to remove by wiping. Often, stains remain if I scrub too hard.
Lukesan
4 Apr 2023 11:05
If a film appears, it may be due to using too much cleaning agent. Simply wipe with a slightly damp cloth and then dry immediately. Avoid leaving any chemical cleaners or soap residues on the surface, as these are the cause of streaks.
Giagau
4 Apr 2023 12:33
I would like to add something: When cleaning melamine-coated furniture, it often helps to use distilled water to avoid lime deposits from tap water, which can appear as white spots or streaks.
Also, I handle Malm furniture very carefully because the coating is not very thick and can be damaged by harsh cleaners or mechanical stress. For removing stubborn stains, I recommend applying a drop of mild, neutral cleaner on a damp cloth and wiping it off thoroughly immediately afterward. You should also avoid using overly wet cloths, as excess water can cause damage.
Does anyone here have experience with home remedies that leave no residue?
