ᐅ How can I install Ikea Metod cabinets in a space-saving way under sloped ceilings?
Created on: 14 Nov 2021 08:37
U
Ulrichro
I am currently planning to renovate my attic and would like to install Ikea Metod cabinets as a storage solution. My main challenge is the sloping roof, which significantly limits the usable ceiling height.
My question is: How can I install Ikea Metod cabinets in a space-saving and functional way under sloped ceilings to maximize storage space while avoiding awkward, hard-to-reach corners?
I am especially interested if anyone has experience with custom adjustments, such as cut-to-size top panels, clever use of cabinet systems, or leveling cabinet heights.
What installation options are available? Are there specific cabinet components from the Metod system to avoid or special accessories that should be used?
I would appreciate tips on suitable dimensions, assembly advice, or concrete design ideas.
Best regards, Ulrich
RON57
16 Nov 2021 11:37
Ulrichro schrieb:
I have a jigsaw but no experience with miter cuts on factory-made panels. Are there any tips on how to achieve a straight and clean cut edge so that nothing splinters and fits well?
Hello Ulrich,
It’s great that you’re taking on the cutting yourself. It is important to secure the panels firmly before cutting, for example with clamps on a workbench.
Use a fine-toothed saw blade, as this helps prevent tear-out and splintering. Applying painter’s tape along the cut line can also help keep the edge intact.
Guide the jigsaw slowly and with even pressure to avoid uneven cuts. If possible, use a guide rail or a straightedge as a cutting guide.
For the doors: Metod fronts can be trimmed directly if you have the necessary skills, or you can have a professional joinery shop make the cuts to ensure clean results.
Alternatively, simple open shelves or drawers offer flexibility if modifying the fronts becomes too complicated.
koduga
17 Nov 2021 08:03
I would like to add that sloped ceilings are particularly challenging, not only from a craftsmanship perspective but also emotionally – it is always frustrating when I buy beautiful cabinets, only to have those awkward angles ruin my plans.
Ulrichro schrieb:
My main problem is the uneven slope, which doesn’t allow for a consistent measurement along the entire length.
I know that very well. Back then, I simulated the slope using thin styrofoam boards or cardboard and tried to see how cabinet units would fit over it. Also, working with modules of different depths helped me – sometimes you can place open shelves behind a deeper front, which are less disruptive on the slope.
It is important not to lose courage and to keep refining the planning. Sometimes it also helps to bring friends in during installation, as a second opinion can offer new perspectives.
If you are still concerned about the fronts: How important is visual uniformity for you? With Metod, you can actually mix fronts of different colors or styles, which gives more flexibility for customization.
