á How do I clean Ikea Metod cabinet fronts when they have stubborn stains?
Created on: 14 Jan 2018 08:12
nosori
Hello everyone, I have a question about the proper cleaning of specific areas on Ikea Metod fronts that have visible dirt buildup or stains, such as dried-on stickiness. I am mainly interested in which cleaning methods and products have proven effective for removing these stubborn residues without damaging the fronts. It would also be helpful to know if there are any cleaning agents to avoid and if you have tips for treating difficult edges or corners. Thanks in advance for your experiences and recommendations!
Hey, I think a little patience goes a long way! đ I usually do it like this: first warm water with some dish soap, then a soft sponge, and for really tough spots, sometimes a gentle brush around the edges. The important thing is not to scrub too hard â the surfaces are delicate. After that, wipe it dry quickly to avoid water spots. This way everything stays clean and shiny!
PRAPI schrieb:
When removing Stolke from Ikea Metod fronts, it is important to avoid using harsh or abrasive cleaners, as the fronts are often covered with a film or coating.Thanks for pointing out the risks! Would you recommend applying the cleaning agents only with a cloth and not spraying them, to prevent moisture damage at the edges? Also, how does this vary with different front materials of Metod â are there differences in how susceptible they are to cleaning damage?
nosori schrieb:
Would you recommend applying cleaning products only with a cloth and not spraying, to avoid moisture damage at the edges?Yes, that is exactly a very good approach! Spraying often causes cleaning liquid to run into the edges or joints, which can lead to swelling or warping of the fronts. Thatâs why I recommend applying cleaning products only to the cloth and not directly onto the fronts.
nosori schrieb:
How does this differ with the various Metod front materials â are there differences in susceptibility to damage from cleaning?Yes, definitely. High-gloss lacquered fronts are somewhat more sensitive to solvents, while foil-covered fronts tend to show scratches more easily. Therefore, always test first! If you have solid wood fronts, they should be treated differently â more with wood care products and less with water.
