ᐅ How can I build an L-shaped combination using Ikea Besta units for maximum storage capacity?
Created on: 28 Jun 2017 18:17
SVENPLO
I am planning to optimize my living space using Ikea Besta systems, arranged in an L-shape for maximum storage capacity. Specifically, I want to know the best way to position and connect the modules to ensure both stability and optimal use of the room layout.
The main points I am interested in are:
- Which Besta components are best suited for the corner combination?
- Are there any special assembly instructions for joining the modules at a 90-degree angle?
- How can I prevent the lower units from sagging or becoming unstable due to weight?
- Has anyone had experience with additional reinforcements or corner connectors?
My idea is to have furniture that offers as much storage as possible without appearing too bulky. Tips on shelves, drawers, or doors in the L-shaped setup are also welcome.
I look forward to your experiences and recommendations!
Jamalli
29 Jun 2017 13:46
Teonon schrieb:
Make sure to use the extra-long corner brackets – they hold very well and provide the necessary stability.
Are the original Ikea brackets always sufficient? I ask because their load capacity often depends on the material used and the quality of the screws.
In my opinion, it’s important to consider whether an additional frame structure makes sense, especially for tall and heavy configurations. Otherwise, deformation may occur over time. Does anyone have long-term experience with such reinforcements?
REOHEINRIC
29 Jun 2017 15:23
Jamalli schrieb:
Are the original Ikea brackets usually sufficient?
In most cases, yes, provided the installation is done properly and the loads remain moderate. For higher loads or frequent modifications, adding an external metal frame can be beneficial.
In a client project, I reinforced the L-shaped cabinet with additional metal brackets at the corners. After two years, there were no deformations or stability issues, even under heavy internal weights.
farli
29 Jun 2017 16:52
REOHEINRIC schrieb:
I added additional metal brackets to the corners of the L-shaped cabinet in a client project.
I’m wondering if this makes the construction significantly more complex and if it negatively affects the visual appearance.
Also, I’m curious whether full-glass or high-gloss fronts might visually complement the corner reinforcement better than other types of fronts.
Danabla
30 Jun 2017 08:17
farli schrieb:
I’m interested to know if this makes the construction significantly more complicated and if it affects the visual appearance?
The additional effort is quite limited. The metal brackets are usually installed in inconspicuous places (inner edges), so they are hardly visible.
Careful planning beforehand is important to ensure a smooth assembly.
Regarding the visual appearance, the brackets do not alter the look of the front surfaces, as these are mounted separately and nothing is covered by the brackets.
SVENPLO
30 Jun 2017 12:39
Danabla schrieb:
Careful initial planning is important, then the assembly proceeds smoothly.
Thanks for the tips so far! I have one last question: Would you recommend fully assembling the modules before corner installation and then connecting them, or installing the individual modules loosely and securing them together directly on the wall?
I ask because achieving a precise 90-degree angle with a fully assembled corner unit might be more challenging than with separate parts.
Also, what about fixing the unit to the wall? Are the supplied wall plugs sufficient, or should more specialized fasteners be used to improve stability?
