ᐅ What is the best way to clean Ikea BESTA furniture without damaging the surface?
Created on: 23 Jul 2021 08:17
SanjoHello everyone, I recently bought an Ikea Besta system and I’m wondering how to clean the surface in the best way without damaging it or affecting the finish.
The surfaces on my model are slightly glossy and made of plastic, not solid wood or metal. I want to remove stains, dust, and fingerprints without using harsh cleaners or abrasive materials that could make the surface dull or cracked.
Are there any specific cleaning techniques or special products you would recommend? Should I avoid anything altogether (vinegar, alcohol, etc.)?
I look forward to your experiences and tips to keep my BESTA looking great for a long time!
The surface of Ikea BESTA is typically made of melamine resin-coated panels or plastic films.
- Use only neutral cleaning agents; mild dish soap solutions are ideal.
- Abrasive cleaners and solvents such as acetone, alcohol, or vinegar can damage the surface and should be avoided.
- For removing stubborn stains, special plastic cleaners are suitable, provided they do not contain harsh ingredients.
- A soft microfiber cloth is best, as it does not scratch and effectively picks up dust.
- After cleaning, always wipe down with clean water and dry the surface to prevent water spots.
I’m happy to help you with a simple step-by-step guide for cleaning your Ikea BESTA surface:
1. Remove dust: Use a dry microfiber cloth to wipe away dust. This protects the surface from scratches.
2. Pre-treat stains: You can wipe off soft dirt with a damp cloth; if necessary, lightly moisten it with a mild soapy solution (e.g., dishwashing liquid).
3. Don’t scrub! To avoid scratches, do not rub too hard and avoid coarse sponges or brushes.
4. Avoid harsh cleaners: Do not use bleach, alcohol, solvents, or vinegar. These can dull or damage the finish.
5. Rinse: Use a damp cloth with clean water to remove any residue.
6. Dry thoroughly: This is important to prevent water spots or swelling at the edges.
If you have a specific stain, feel free to describe it, and I can give you a tailored tip. Sometimes, just a little time and a soft cloth work best.
I can understand very well that when you have a new piece of furniture, you might feel uncertain about how to properly care for it. I had a similar experience with my BESTA shelf and was also worried about accidentally damaging the surface.
Your caution is justified: it’s better to use cleaning products sparingly and carefully. What helped me was relying on natural agents and mild products. Additionally, I find a soft microfiber cloth indispensable – it helps prevent many scratches.
Maybe you could plan your cleaning seasonally or, in case of heavier dirt, wipe more often gently rather than scrubbing aggressively. How do you handle it at the moment? Have you already tried any cleaners?
As an additional note, it is advisable to ensure that no standing moisture remains on the edges when cleaning BESTA. These edges often consist of particleboard underneath the veneer and tend to swell if exposed to prolonged dampness.
I always use a soft cloth, dip it in lukewarm water with a little mild dish soap, then wipe the surface and follow up with a dry cloth to remove any remaining moisture.
Please also avoid spraying cleaners directly onto the surface – always apply them to the cloth, not the furniture.
This protects the surface and prevents liquids from penetrating the joints.
