Hello everyone, I am planning to better organize my hobby room and am considering how to use Ikea Besta most efficiently as a storage solution. My main question is: How can I configure and expand the individual Besta units to store different types of hobby materials—such as tools, smaller electronic components, and larger craft supplies—safely, clearly, and ergonomically? Are there any special tips or accessories that have proven particularly useful for use in a hobby room? I would like to create as much storage space as possible while also allowing quick access to frequently needed items. I would also appreciate ideas for labeling or separating the compartments.
Basically, Ikea Besta is well suited for hobby rooms because the modules can be combined very flexibly. For your requirements, I recommend: - Using drawer inserts for small items to ensure clear separation and organization. - Adding extra shelves to make optimal use of the height, especially for larger craft supplies. - Utilizing the inside of the doors with hook rails or magnetic strips for tools. - If dust protection is desired, doors with glass fronts seem suitable, as they allow you to see the contents while keeping them protected. Labels work well with wipeable adhesive labels or small wooden signs that can be clipped in. It is important to consider the depth of the Besta modules (40 cm [16 inches] standard) during planning to accommodate bulkier items properly.
minKarson20 Apr 2017 20:27Use drawer boxes in the Besta shelves. This way, you can organize small items neatly and access them quickly. Doors with flap panels help prevent dust buildup.
Hello Ianko, I completely understand that you want to design your hobby room to be both functional and well-organized. Besta offers many possibilities through its modular design to achieve exactly that. One approach I have tried myself is combining open and closed elements: for example, closed compartments at the bottom to keep dust away and hide unattractive materials, and open compartments or ones with glass fronts at the top so you can quickly see what you have. For better organization, plastic boxes of different sizes are useful; these can either be stacked or placed inside the compartments. This way, you can organize various materials, such as: - Sorting tools by function - Dividing electronic components into small boxes - Storing larger craft supplies like fabrics or spray paints in bigger containers If you want frequently used items within easy reach, I recommend storing them in lower compartments or in the top drawers, as these tend to be more accessible. Labeling also helps, especially if you have many different materials. The best way is to find out for yourself which combination of visibility and protection works best for you. I wish you the best of luck with your design!
Dwight49 schrieb:
The inside surfaces of the doors can be used with hook rails or magnetic strips for tools. This is definitely an added benefit; however, I would question whether the standard Besta units are sufficiently sturdy in terms of door load capacity and hanging solutions for heavier tools. Especially with larger power tools or heavy pliers, there could potentially be issues. It might be better to use the wall behind the Besta shelves for strong hooks or a perforated metal panel (pegboard) and reserve the Besta units for lighter or more delicate items. This way, the storage solution remains ergonomic and safe.
