ᐅ IKEA Besta – which seals can I use to protect against dust?
Created on: 15 Jul 2024 08:43
tachristin
tachristin
15 Jul 2024 08:43
I would like to better protect my IKEA Besta shelving unit in the living area from dust. Although the doors close, dust still seems to get inside from time to time, which is frustrating for sensitive devices and documents. Therefore, my question to the community:
What types of seals can I effectively install on the Besta doors to minimize dust entry?
It is important that the solution is not too complicated to install, does not damage the wood or surface, and also takes the appearance into consideration, since the unit is visible in the room.
Has anyone had experience with special rubber seals, brush seals, or other materials that are recommended for the IKEA Besta?
Thanks in advance for your tips and suggestions!
sanjon
15 Jul 2024 09:02
for the windows, you can use self-adhesive rubber seals that are applied to the doors. Just make sure they are not too thick, otherwise the door will jam.
GiRoyce
15 Jul 2024 09:18
I can understand your situation well; dust can sometimes be a real issue with open or not fully sealed furniture like the Besta.
In general, I recommend using seals made of soft silicone or rubber, which you can find as sealing strips in hardware stores or online. It is important that the seal is flexible enough to fit well to the door and frame.
Alternatively, brush seals can also be a good option. They are somewhat more flexible and create a slight buffer without damaging the door. The brushes basically sweep away dust before it enters the cabinet.
Before installing, make sure to clean the surfaces thoroughly (with alcohol or a grease-removing cleaner) so that the adhesive strips stick properly.
I would suggest testing the seal on one door first to see how it feels and whether it closes well before installing everything.
ju_ren
15 Jul 2024 09:22
Rubber profiles measuring 5x5 mm (0.2x0.2 inches) work well. Simply glue them to the inside of the frame so that the door closes against the rubber.
dijan
15 Jul 2024 10:04
Looking for a deluxe dust stopper for Besta? 😄
I installed brush seals on the inside edge of the door. They act like small brooms in the door frame – making it hard for dust to get in.
They are visually quite discreet, available in black or gray, and if you want it practically "dust-tight," you can combine them with rubber seals. The result: less dust, reduced cleaning effort, and more protection for the equipment inside the cabinet.
But be careful when measuring: the seal should not be too thick, otherwise the doors will become difficult to close, which can quickly become annoying.
Good luck – and dust won’t stand a chance anymore!
blapau
15 Jul 2024 10:38
As an addition:
When applying seals to Besta doors, it is important to ensure material compatibility. Many self-adhesive seals use acrylic adhesive, which can negatively affect some painted surfaces if removed later.
Alternatively, softer silicone profiles can be used. These provide better sealing. Profiles with a thickness of about 3-6 mm (0.1-0.25 inches) are recommended to ensure sufficient compression without overly restricting the door.
A combination of a brush seal for dust and a rubber seal for drafts can also offer a good compromise. Additionally, the temperature and humidity conditions in the room should not be overlooked, as they affect the seal’s durability.
Before installation, I recommend performing a small test in an inconspicuous area.
