Hello everyone, I plan to mount IKEA Metod kitchen fronts on a wall that is unfortunately not completely flat. The irregularities are noticeable in some areas, so the fronts do not sit flush horizontally or vertically without adjustment. My question is which methods or tools you would recommend to ensure a clean and stable installation of Metod fronts on such uneven surfaces? Specifically, I am interested in
- how to compensate for unevenness,
- whether special spacers, washers, or mounting systems make sense,
- and if certain fastening methods (e.g., special brackets, adapters, or insulated supports) are better suited for the IKEA Metod fronts.
I have some experience with furniture assembly but want to be absolutely sure that the fronts fit well over the long term and do not cause gaps or misalignment issues. Thank you for your tips!
I know how frustrating uneven surfaces can be – even with modern furniture assembly. What helped me was temporarily attaching the fronts first and then aligning them step by step using spacers. It’s important not to get discouraged; IKEA fronts are often a bit flexible and distribute weight well. If you notice gaps forming despite all efforts, it’s often due to the wall itself – in this case, adding extra sheathing with OSB or drywall can be a useful solution.
Henry schrieb:
If you notice gaps forming despite all precautions, it is often due to the wall itself – in this case, adding an additional layer with OSB or drywall can be helpful.That’s an interesting point, thank you! Unfortunately, the uneven wall is made of solid concrete, and the surface is slightly wavy. From your perspective, would it be better to install some kind of substructure before fitting the panels? Or can adjustable fastening systems be used directly on the wall if adjusted carefully?
