ᐅ How do I attach IKEA Metod kitchen fronts to uneven surfaces?
Created on: 1 Jun 2015 14:07
jason2
jason2
1 Jun 2015 14:07
Hello everyone, I plan to mount IKEA Metod kitchen fronts on a wall that is unfortunately not completely flat. The irregularities are noticeable in some areas, so the fronts do not sit flush horizontally or vertically without adjustment. My question is which methods or tools you would recommend to ensure a clean and stable installation of Metod fronts on such uneven surfaces? Specifically, I am interested in
- how to compensate for unevenness,
- whether special spacers, washers, or mounting systems make sense,
- and if certain fastening methods (e.g., special brackets, adapters, or insulated supports) are better suited for the IKEA Metod fronts.
I have some experience with furniture assembly but want to be absolutely sure that the fronts fit well over the long term and do not cause gaps or misalignment issues. Thank you for your tips!
Z
zartra
1 Jun 2015 14:22
To even out irregularities, you can place small wooden or plastic wedges behind the hinges. Alternatively, self-adhesive spacers can also be used. It is important that the panels are securely fixed and still adjustable.
noge58
1 Jun 2015 15:45
Hey Jason, I had a similar issue with my kitchen! What worked really well were flexible rubber pads that I placed at the fixing points. This allowed me to compensate for unevenness, and the fronts fit perfectly afterwards. So don’t get discouraged, you can manage it! The Metod fronts are really sturdy, and with a bit of patience, it looks great!
glamo8
1 Jun 2015 16:18
For uneven surfaces, it is advisable to fix the fronts using adjustable brackets. These can be adjusted to different depths, ensuring an even fit.
jason2
2 Jun 2015 08:32
noge58 schrieb:
What really worked great were flexible rubber washers that I used at the mounting points.
Thanks for the tip! How thick were these washers for you, and did you place them directly under the hinges or at other locations? Did you use anything special for this purpose that is temperature- or moisture-resistant?
NoValentin
2 Jun 2015 09:14
I placed PU foam pads behind the hinges on my kitchen cabinets. They are thin, flexible, and press the doors firmly against the wall. This holds securely over time and cushions minor irregularities.
