ᐅ How can I securely attach Ikea Metod kitchen cabinets to very rough walls?
Created on: 6 Nov 2020 08:43
Serhat55
Serhat55
6 Nov 2020 08:43
I am currently planning to install my Ikea Metod kitchen cabinets on a wall that is unfortunately very rough and uneven. It is an old concrete wall with a coarse texture, some chips, and small irregularities of up to 1.5 cm (0.6 inches). My question is: How can I securely and stably fix Ikea Metod kitchen cabinets to extremely rough walls?
I want to avoid the cabinets wobbling or loosening over time. Which types of drill bits and wall anchors are recommended here, and how can I compensate for the unevenness as much as possible without having to extensively smooth the entire wall?
I would appreciate any tips on materials, tools, and procedures. Maybe someone has experience with similar walls or can provide a complete step-by-step guide. Thanks in advance!
Lilygla
6 Nov 2020 12:37
Hello Serhat55,
Your issue is indeed complex but can be solved with some careful planning. First: The Ikea Metod cabinet system requires secure anchoring points – these are usually designed for relatively smooth walls with a load-bearing substrate.
An extremely rough and uneven wall like your old concrete wall with irregularities up to 1.5 cm (0.6 inches) is a challenge because the backs of the cabinets should sit flush against the wall.
Here is my practical suggestion in several steps:
- Wall preparation: Small unevenness up to 5 mm (0.2 inches) can be smoothed out with flexible filler. For 1.5 cm (0.6 inches) irregularities, I recommend initially filling the deeper spots with filler or fast-setting mortar to close large indentations. The advantage: you increase the supporting surface area for the cabinets.
- Alternatively, you can install a substructure – for example, a horizontal battens frame made of wood (e.g., construction timber 30x50 mm (1.2x2 inches)). This can be fixed to the rough concrete wall using appropriate heavy-duty anchors (nylon or metal, depending on the drilled hole). The battens provide a flat mounting surface and compensate well for unevenness.
- The Metod cabinets are then mounted onto this substructure, minimizing stress on the wall.
Regarding anchor selection:
- Use metal anchors or heavy-duty anchors certified for concrete surfaces.
- Ensure you drill deep enough (at least 8 cm (3 inches)).
Tools:
- Rotary hammer with suitable concrete drill bit
- Spirit level
- Screwdriver with a long bit
I recommend drilling the holes as straight as possible with minimal vibration to avoid chipping.
One more question: Are these wall cabinets, base cabinets, or both? The mounting requirements differ slightly depending on the load.
Summary: Level out irregularities with filler or battens, use sturdy heavy-duty anchors, and carefully align using a spirit level. If you like, I can also prepare a detailed list of materials and tools for you.
SUDAN
6 Nov 2020 15:58
Lilygla schrieb:
Level unevenness using filler or a batten framework, use strong heavy-duty anchors, and carefully align with a spirit level.
I agree with this advice and would like to add a simple step-by-step process that has helped me many times:
- Step 1: Inspect the wall and mark the fixing points using a leveling device or laser level.
- Step 2: If unevenness exceeds 10 mm (0.4 inches), install a subframe made of wooden battens or OSB (Oriented Strand Board) panels. OSB panels are stiffer and provide more stability than battens alone.
- Step 3: Attach the subframe using concrete anchors (e.g., nylon expansion anchors or metal anchors). Important: clean the drill holes from dust before inserting anchors to ensure optimum hold.
- Step 4: Fix the Metod kitchen cabinets to the subframe with screws (Ikea supplies appropriate mounting profiles).
- Step 5: Finally, check for evenness and secure the cabinets against tipping with angle brackets or metal fasteners.
Common mistakes to avoid:
- Using anchors that are too small (e.g., only 6 mm (0.24 inches) in diameter for a concrete wall is often not strong enough for kitchen cabinets).
- Drilling holes that are too shallow or at an angle.
- Not cleaning out the holes – dust significantly reduces holding strength.
If you do not want to use a subframe and the unevenness occurs only at a few points, you can use spacer washers to bridge the gap between the cabinet back panel and the wall. However, this is uncommon and not ideal for heavy kitchen cabinets.
I hope this helps you.
Deoren
7 Nov 2020 09:16
Serhat55 schrieb:
How do I securely and stably attach Ikea Metod kitchen cabinets to extremely rough walls?
I would install a wooden framework first, and then hang the cabinets on it. This way, you can compensate for any unevenness, and the cabinets will hang securely.
bupar
8 Nov 2020 11:23
Lilygla schrieb:
Use metal anchors or heavy-duty anchors certified for the substrate when fixing into concrete walls.
This is a crucial point. Additionally, I want to emphasize that the load-bearing capacity of old concrete walls may be reduced due to crack formation. If you have any doubts, chemical anchors (injection anchors) might be more suitable. These distribute the load more diffusely within the masonry and are less prone to breakout failures.
Furthermore:
- Use drill bit diameters according to the anchor manufacturer’s specifications.
- Use a cleaning needle and blower to completely remove dust from the drill hole.
- Check for irregular wall positions before fastening with a digital inclinometer.
Wooden substructures are advisable because they efficiently compensate for unevenness and ensure stable load distribution. Especially for wall cabinets, this prevents potential damage to the masonry and provides long-term stability.
Without a substructure, you increase the risk that anchors are not optimally loaded due to wall roughness or that damaged areas may expand under load.
My conclusion: Use a stable substructure to which you attach the cabinets, and rely on suitable anchors or chemical fixing, particularly for coarse concrete with cracks or spalling.
