ᐅ IKEA Besta – How Can I Replace Damaged Panels Myself?
Created on: 3 Nov 2016 18:07
SOBIREO
I own several IKEA Besta cabinets, and unfortunately, some of the panels are damaged—whether from scratches, dents, or slight warping. Since I would like to maintain and repair the furniture myself, my question is: How can I independently replace the damaged panels on IKEA Besta cabinets without having to disassemble or discard entire units?
I would appreciate information on which tools are needed, the best way to remove and reinstall the panels, and any particular points to watch out for to avoid causing further damage to the furniture.
Additionally, I am interested in whether original replacement parts from IKEA are available for purchase or if alternative options are recommended.
I look forward to your tips and experiences!
RuPablo7
3 Nov 2016 21:03
Just a quick note: Once you have located the screws on the connectors, you can often remove the panels without completely disassembling the structure. Just take the doors out and you’re good to go.
risar
4 Nov 2016 08:15
I would like to add that in older Besta models, there can sometimes be variations in the construction. The panels may use different types of connections, such as dowels instead of screws. This can make replacement a bit more complicated.
If you are unsure, take your time and work carefully. Especially with damaged panels, it is important to avoid causing further damage.
Also, if you order replacement parts from IKEA, make sure to check if your model series is still available. Otherwise, you can resort to custom-made parts from wood or MDF, although these might not be quite as stable or precise.
I hope this helps you.
fiman
4 Nov 2016 10:34
It’s best to remove the fronts first; then, after loosening the screws, the panels can be easily taken out. You might want to check with IKEA customer service about replacement panels.
SOBIREO
4 Nov 2016 11:55
FRAVIN schrieb:
IKEA usually offers spare parts only through customer service if you have the exact product number. You can find this under the panels or in the assembly instructions.
Is there an official source or a dedicated IKEA contact for ordering replacement parts? It’s a bit complicated for me since I own different Besta models. Should I simply provide the receipt, or does it also work without proof of purchase?
Also, if you have any experience with the quality of the replacement panels, I would be interested to hear about it.
U
USKIPA
4 Nov 2016 13:29
At IKEA, customer service for replacement parts is usually the right contact, so it is best to call them directly or inquire at the nearest store.
The purchase receipt can be helpful but is not always required – often the product number or a detailed description is sufficient.
Regarding the quality of replacement panels: they generally match the original parts, but appearance and color may vary slightly depending on the batch.
Daledra
5 Nov 2016 09:18
Summary:
- Replacing panels on Besta units is usually possible by removing the fronts
- Tools needed: Allen key, screwdriver, pliers
- Best to request replacement panels through IKEA customer service (product number and, if available, proof of purchase)
- Remove old panels carefully, avoid overtightening screws
- For older models, pay attention to dowels and other connectors
- Alternative: custom-made panels from a carpenter, but this is more expensive and may differ in color
This should prepare you well.
