ᐅ How do I assemble IKEA Metod cabinets with sliding doors?
Created on: 20 Jan 2024 08:34
Saukla
Saukla
20 Jan 2024 08:34
I am currently facing the challenge of assembling Ikea Metod cabinets with sliding doors and hope to find some expert advice here in the forum. Specifically, I want to understand the correct steps and tips for properly installing this combination.
I have already looked at the assembly instructions, but I am unsure about how to properly attach the sliding door mechanism, as the sliding doors don’t seem as straightforward as regular hinged doors. Additionally, I am interested in whether there are important details to consider when aligning and adjusting the sliding doors to ensure they operate smoothly without sticking or scraping.
For background: I have two Metod tall cabinets that I want to install side by side, each fitted with white sliding doors. The cabinets will stand on a wooden floor, and I plan to make the most of the installation space.
Maybe someone has experience with the exact installation process, tips for mounting the running rails (especially top and bottom), and advice on fine-tuning the sliding doors. Perhaps there are also tricks for achieving a more stable setup for the sliding door systems.
Thanks in advance for your help!
Jeanbar
20 Jan 2024 09:12
Hello Saukla,
I can well understand that assembling Ikea Metod cabinets with sliding doors can be a bit tricky, especially if you are used to traditional hinged doors.
Basically, I recommend assembling the tall cabinets carefully according to the instructions before you start installing the sliding doors. The tracks are usually mounted at the top and bottom on the cabinet sides. It is crucial to work very precisely and especially plumb, because sliding doors require exact alignment to slide smoothly. Even small inaccuracies can cause the doors to stick or make scraping noises.
A helpful tip: check with a spirit level that the cabinet and tracks are perfectly straight, and adjust accordingly. The sliding door systems in Metod often allow fine adjustment via screws on the runner rails and brackets. These screws should be tightened only lightly at first, so the doors can still move without force, and then gradually tightened once everything runs perfectly.
I also recommend installing the doors only once the cabinets are firmly positioned in their final place. With sliding doors, even the smallest movement of the cabinet becomes noticeable.
Do you have a specific dimension or door type you are installing? Sometimes the systems differ depending on the width or weight of the doors.
Feel free to get in touch if you want more details on any of the steps!
GOLO42
20 Jan 2024 11:03
Jeanbar schrieb:
Basically, I recommend assembling the tall cabinets completely according to the instructions before you start installing the sliding doors.
This is a very important tip. I’d like to add to it with some technical details that are often overlooked when assembling Metod cabinets with sliding doors.
First, you should definitely check the floor surface: uneven floors can affect the entire cabinet structure, which is especially problematic with sliding doors. A stable base is essential. It’s advisable not only to secure the cabinet to the wall but also to adjust its position on the floor using feet or leveling screws. Ikea usually provides height-adjustable feet for this purpose, which you can install underneath.
Regarding the sliding door mechanism, keep the following in mind:
- The running rails must be installed precisely at right angles and at the same height.
- Before installing the doors, always check the rollers for damage or foreign objects.
- Sliding doors are usually hung first and then adjusted. There are typically adjustment screws to fine-tune the height and tilt of the doors.
- When aligning the doors side by side, make sure there is an even gap so they don’t rub against each other when closing.
Incorrect installation or imprecise adjustments often cause the doors to jam, become misaligned, or produce noise when opening and closing.
One more tip: if you place two cabinets next to each other, it can be helpful to install the sliding door systems so that both doors open smoothly without one door interfering with the other. Plan the running rails accordingly.
If you like, you can share more about your room and flooring, and I can provide more specific advice on fastening and assembly.
geralu
20 Jan 2024 11:47
First, build the complete cabinet and align it precisely. Then install the sliding tracks: top and bottom, parallel. Hang the doors, then adjust them. Important: Do not tighten the screws on the sliding door system too early. This allows for fine adjustments until everything operates smoothly.
Saukla
21 Jan 2024 07:22
GOLO42 schrieb:
Incorrect installation or imprecise adjustment often causes the doors to stick, become misaligned, or make noises when opening and closing.
The topic of adjustment and misalignment concerns me the most. I have heard that with Metod sliding door mechanisms, it is possible to individually adjust the door height and the track.
Does anyone have experience with how exactly these adjustment screws work or how I should best proceed to get the doors to run perfectly side by side, especially when two cabinets are placed next to each other?
Also, I wonder whether it is advisable to check and readjust the running rails multiple times, or if it is better to install them precisely once and then leave them unchanged.
Are there any early signs that indicate the doors are not set correctly?
I look forward to any tips and advice!
Jeanbar
21 Jan 2024 08:16
Saukla schrieb:
Does anyone here have experience with how exactly these adjustment screws work or the best way to get the doors to run perfectly side by side?
Yes, the adjustment screws on the rollers allow you to change the height of the door, which is very useful for compensating minor floor unevenness or slight differences in cabinet heights.
I recommend leaving the doors hanging while adjusting the screws with an Allen key or screwdriver. By turning them carefully, you can raise or lower the door in small increments.
When two doors run side by side, it is important to check the gap between the doors—it should be even so that edges do not touch. This gap is also influenced by the adjustment.
Saukla schrieb:
Should the tracks be checked and adjusted multiple times after installation, or is it better to install them precisely once and then not alter them?
Ideally, the tracks should be installed as precisely as possible, but in practice, they should be checked and possibly fine-tuned after installation and some test openings. Avoid tightening the screws too much so that there is still room for adjustment.
Saukla schrieb:
Are there early signs that indicate the doors are not properly adjusted?
Yes, typical signs include uneven or jerky movement when sliding, noises like scraping or rattling, or if the doors do not close smoothly. If the doors stick or do not run parallel, it is a clear indication that they need adjustment.
