ᐅ How do I install Ikea Metod kitchen cabinets with different types of doors?
Created on: 12 Mar 2023 09:17
kakla51
kakla51
12 Mar 2023 09:17
Hello everyone, I am currently planning to assemble several Ikea Metod kitchen cabinets and am a bit unsure about choosing the doors. My main question is: How do I properly assemble Ikea Metod cabinets with different door types such as folding doors, swing doors, hinged doors, and also sliding doors? I am especially interested in the differences during installation, the special requirements for fittings, and any potential pitfalls related to the various door types. Since I am also planning combinations of different door styles, it would be helpful to know what to watch out for when making adjustments and how the everyday wear and load affects each door type. I look forward to your tips, experiences, and specific advice on assembling Metod cabinets with different doors.
liskar
12 Mar 2023 11:04
When assembling Ikea Metod cabinets with different types of doors, it is essential to pay close attention to the compatibility of the fittings.
- Hinged doors typically use Metod hinges, which can be precisely adjusted.
- Folding doors require special folding door fittings, as the doors interlock. It is especially important to correctly align the tracks here.
- Sliding doors need a track and rollers that must be precisely aligned to ensure proper functionality.
It is important to carefully review the included assembly instructions, as different doors also require different screws and types of fittings.
When combining different types of doors, it is helpful to consider the load on the fitting points, since folding doors tend to transmit slightly more mechanical force to the hinges due to their design.
PAREL
12 Mar 2023 13:29
I am happy to provide you with a step-by-step guide for assembly with various types of doors:
Introduction:
- Prepare all components and sort them by cabinet and door type.
- Check all fittings for completeness.
Hinged Door Installation:
- First, screw the METOD hinges onto the doors.
- Position the doors correctly on the cabinet frame.
- Adjust the hinges to achieve perfect alignment.
Folding Door Installation:
- Attach the running and folding door fittings to the cabinet frame and doors.
- Pay special attention to ensure the tracks run freely and parallel.
- Test folding and opening several times.
Sliding Door Installation:
- Install the upper track and the guiding elements mounted at the bottom.
- Insert the sliding doors and check for smooth operation.
Summary: Different door types require precise preparation of fittings and adjustments. Always use the instructions as a reference and do not skip any steps.
ju_ren
12 Mar 2023 14:47
Swing doors: Install and adjust hinges.
Folding doors: Align tracks precisely.
Sliding doors: Check runners and rollers.
Pay attention to load, especially with folding doors.
Bagupo
12 Mar 2023 15:33
Look, with folding doors it is important that the doors fit well into each other; otherwise, you will have problems closing them.
Sliding doors only make sense if you have enough space and they don’t interfere with other doors.
PULAU
13 Mar 2023 08:12
An important tip: When combining different types of doors, especially check the load capacity of the fittings.
Metod hinges for hinged doors are sturdy, while folding door fittings are mechanically more complex and require precise work during installation.
The load on the cabinet can also be higher with sliding doors, particularly when multiple doors run parallel. Make sure the running tracks are securely fastened.
