ᐅ How can I best adapt IKEA PLATSA furniture for sloped ceilings?
Created on: 14 Jul 2020 09:37
barjo
Hello everyone, I am planning to install IKEA Platsa furniture in a room with sloped ceilings and am wondering how to best adapt these units to the angled walls. Since PLATSA is quite modular, it seems there are many possibilities, but I am encountering some challenges during the planning stage, especially regarding the covering of the top edges and adjusting to different slope angles.
My goal is to integrate the furniture seamlessly into the sloped ceiling without gaps or negatively affecting the appearance. Does anyone have experience or tips on the best ways to modify PLATSA furniture for this? I am particularly interested in advice on measurements, help with angle adjustments, possible complementary furniture from IKEA, or DIY options. Thank you in advance!
Nadine
16 Jul 2020 08:42
Hello barjo,
I can add that when dealing with sloped ceilings, it often helps to use so-called “wedge panels” or custom-cut poplar plywood sheets that are installed between the furniture and the slope. This way, the angled surface can be visually balanced and gaps can be closed without having to do too much cutting on the main furniture pieces.
Also: If you plan to attach the furniture to the slope, be sure to check which anchors and screws you are using. Especially with lightweight drywall, you should be cautious and, if necessary, fix into the roof structure itself.
If you are concerned about precision, a skilled carpenter friend can often help to professionally create the suitable angles and parts.
WARREN
16 Jul 2020 11:03
For sloping ceilings: Use a bevel to determine the angle, leave the Platsa element at the bottom, and cut and attach fitted cover strips at the top. No need to completely trim the side panels. This way, stability is maintained.
