ᐅ Are there any tips for using Ikea BESTA units effectively on sloped ceilings?
Created on: 12 Jan 2023 16:07
Kau63Hello everyone, I am planning to furnish my living room with the Ikea Besta system, but I have a challenge: the corner of the room is under a sloped ceiling, which makes it difficult to place standard furniture there both elegantly and functionally. Do you have any tips on how to integrate the Besta system well under sloped ceilings? It is important for me to have a clean look, optimal use of storage space, and minimal waste or costly modifications. Perhaps you have experience with custom cuts, combinations of modules, or creative installation options? I look forward to your suggestions and practical recommendations!
Hey Kau63, great question! The BESTA system is really versatile, offering a lot of possibilities! 😊 One tip: use the lower BESTA units for areas under the sloped ceiling, then place open shelves or short base cabinets above them. This avoids a bulky look and helps the design blend in nicely. You can also experiment with shelves at different heights to get the most out of the space! Don’t be discouraged—custom measurements are sometimes an option, but often a little creativity with the layout is enough!
For integrating Ikea BESTA units under sloped ceilings, I recommend the following approach:
- Measure the slope precisely to determine the exact room height and depth
- Use the lower BESTA variants, such as 38cm (15 inches) height or 38cm (15 inches) depth, to create space under the slope
- Combine with open shelves in the upper area for a visually lighter effect
- Custom cutting of shelves or the back panel is possible with appropriate tools to avoid unnecessary gaps
- Use angled support feet or brackets for secure installation
These tips are based on proven practical solutions and enable an elegant and functional result.
