I am planning to set up some Ikea Brimnes furniture pieces in my attic room. However, I have the problem that the sloping ceilings significantly limit the wall height and room depth. My question is: how can I adapt Ikea Brimnes furniture to sloped ceilings so that they remain functional and visually appealing?
I am interested in practical modification options (such as cutting, adjusting the back panels or surfaces) as well as tips for installation or combining them with other built-in elements.
Are there any experiences with sawing, custom-made additions, or specific Brimnes models that work better for these kinds of spaces? I am reasonably handy and can use tools, but I don’t want to damage anything.
Thanks in advance for your tips and advice!
Hey Bentpe41!
That’s a great question – Brimnes is quite sturdy, but the sloped ceiling can really be frustrating. 😅
I simply trimmed the back panel at the top of the cabinet, which worked well using a jigsaw. Just make sure to sand all the fresh cut edges thoroughly and seal them with paint or veneer, otherwise moisture can get in quickly.
Additionally, I secured the cabinets to the slope using small brackets to keep everything steady. Maybe you could also cut some shelf boards to fit between the wall and the furniture for extra stability.
Feel free to ask if you need advice on tools, I’m happy to help! 😉
Hello Bentpe41,
to adapt an Ikea Brimnes wardrobe to fit a sloping roof, I recommend the following approach:
- First, measure the location of the sloping roof precisely and transfer the dimensions onto a cutting template.
- The top of the back panel can be easily cut along the slope using a jigsaw or a circular saw.
- Depending on the model, you may also be able to adjust the side panels. Make sure that the stability of the furniture is not compromised.
- Use sandpaper to smooth all cut edges, then apply a suitable finish (paint or veneer) to protect the cut surfaces.
- For attaching the wardrobe to the sloping roof, angle brackets or corner braces work well. These can be fixed inside, either screwed into the wall or the furniture frame.
An important tip: always work in small steps and regularly check the fit to avoid cutting too much.
If you like, I can also provide a sketch or more details on the individual steps.
I think it makes sense to question the basic idea: Ikea Brimnes is generally a box furniture piece with fixed dimensions, designed for standard wall heights.
Adapting it to sloped ceilings can basically only work by cutting it apart and resizing. However, this often leads to stability issues and aesthetic compromises.
One possible alternative would be to combine individual modules or cabinets with open tops or shortened carcasses, and possibly build a custom-made cover or paneling on top that better follows the slope, instead of modifying the furniture directly.
Do you have any ideas or experience on how to reliably avoid stability problems with such modifications? Or is professional carpenter work probably advisable in such cases?
Tinaneo schrieb:
Adjusting to sloped ceilings basically only works by disassembling and cutting anew.That sums it up quite well.
I once adapted a Brimnes shelf for friends to fit under a sloped ceiling. It’s important to carefully plan which parts you will shorten—and accept that the furniture won’t look 100% original anymore.
Here are a few tips from my experience:
- Cutting back panels is usually not problematic.
- Be very careful with the side panels, as they bear a lot of load.
- Consider reinforcing them with small wooden supports on the sides.
- If possible, avoid pressing the furniture directly against the slope. Leave some space and insert small cover strips in between.
I’m happy to offer advice on tools or small parts like screws or brackets—just ask.
