I am planning to install new shelves in my attic room, and I want to use Billy bookcases from Ikea. However, the room has sloped ceilings, which makes the layout a bit unusual. So my question is: Which Billy bookcases are suitable for sloped ceilings to make the best use of storage space while also looking good?
Are there specific models, sizes, or accessories I should consider to integrate the angled walls as well as possible? I would also appreciate any tips on how to adjust the shelves so they remain stable and visually appealing despite the sloped ceiling.
Thanks in advance!
Thanks in advance!
The classic BILLY series is not specifically designed for sloped ceilings, but with different heights (e.g., 106 cm (42 inches), 202 cm (80 inches), 237 cm (93 inches)), flexible solutions can be created.
For sloped ceilings, the lower version (about 106 cm (42 inches)) is usually recommended, as it can be adjusted to fit the slope. Additionally, the shelf can be fixed directly to the wall to ensure stability.
Some users shorten the back panel or modify the side panels to follow the slope line. Ikea also offers the option to remove or reposition individual shelves, providing additional flexibility. It is important, however, to always keep the maximum load capacity of the shelves in mind.
To answer the question precisely about which BILLY shelves are particularly suitable, it is necessary to consider the dimensions and the room situation. BILLY is standardly rectangular, meaning it is not specifically designed for sloped ceilings, but the following tips are helpful:
1. BILLY 106 cm (42 inches): Lower height, ideal for filling the lower part of a sloped ceiling. The advantage here is fewer modifications required.
2. BILLY 202 cm (79 inches) or 237 cm (93 inches): Taller options for areas without a slope or if you want to cut or modify the shelf.
3. Assembly: Stability issues can be controlled by securing the shelf to the wall and using built-in supports.
4. Modifications: Cutting the sides or back panels is possible with woodworking tools, but pay attention to maintaining structural integrity.
5. Accessories: Clamps, wall mounts, back panels, and matching shelves.
My recommendation: First place the 106 cm (42 inches) high shelf under the slope, and consider combinations with lower or narrower versions in recesses.
For better planning, exact measurements of the sloped ceiling would be helpful. How deep is the slope, and at what approximate angle is it positioned?
bapar schrieb:
For better planning, exact measurements of the roof slope would be helpful. How deep is the slope, and what is its approximate angle?Thanks for the advice!
The roof slope starts at about 1.30 m (4 ft 3 in) in height and then descends towards the floor at an angle of approximately 40 degrees. The room depth is around 3.5 m (11 ft 6 in). The slope extends along a length of about 2 m (6 ft 7 in).
I thought the 106 cm (42 inches) units would actually be the best fit to build shelves under the slope, possibly combined with standard BILLY shelves for the taller areas.
For this angle and height, would it make sense to cut the shelves at an angle or just adjust the side panels? Stability is very important to me since I want to store books.
That sounds really well planned on your part! 🙂
I also have a sloped ceiling in my attic with a similar angle (about 38 degrees) and installed BILLY shelves at a height of 106 cm (42 inches). It was very easy because I simply shortened the back panels at the bottom so they fit perfectly into the sloped corner.
Adjusting the side panels was a bit more challenging, but it’s doable with a jigsaw.
What I also find great is that the shelves can be repositioned flexibly using the dowels – so you can basically customize everything according to your needs.
You might want to try adjusting only the back panels first and see how the shelf fits. 🙂
To be honest, I find it a bit questionable to repurpose BILLY for sloped ceilings. It’s well known that this shelving unit is a simple, straight-lined system not designed for angled walls.
Honestly, instead of constantly modifying and cutting, why not just buy a custom furniture system or a shelf specifically made for slopes? That way, you can avoid a lot of adjustments and headaches.
Exactly – so why insist on using something that doesn’t fit? Just because the name is familiar? Sometimes it’s better to be pragmatic.
SUBEN60 schrieb:
The classic BILLY series is fundamentally not designed specifically for sloped ceilings
