ᐅ How can I securely build IKEA Platsa furniture on sloped ceilings?
Created on: 1 May 2024 08:42
Nekarste62
Nekarste62
1 May 2024 08:42
I am planning to furnish my attic with IKEA Platsa furniture, but I am facing the challenge of the sloping roof. I am particularly interested in how to properly and securely install the individual Platsa cabinets or modules on the slopes so that they not only fit visually but also stand firmly and can bear weight.
Are there tested methods to firmly and safely fasten the furniture despite the unusual angles? A solution that does not require modifications to the furniture or can be implemented with simple adjustments would be especially important for me.
Does anyone have experience with handling sloping ceilings using the standard dimensions without losing stability? I would appreciate tips, recommendations on fasteners, and, if possible, any reports on how you adapted Platsa furniture to inclined walls.
Thank you very much in advance for your help!
koduga
1 May 2024 09:15
Hello Nekarste62,
I can relate to your challenge because I had almost the same issue with my loft conversion. What really helped me was fastening the modules directly to the wall at several points. I used longer screws and special angle brackets that can also compensate for slight alignment deviations.
Stability is truly the most important factor; otherwise, you quickly lose enjoyment of the setup. I also found it useful to add a skirting frame to the bottom of the modules to prevent slipping on the slope.
What exactly does your roof structure look like? Providing more details could definitely make it easier to exchange ideas.
meGreg
1 May 2024 09:37
Hey Nekarste62,
interesting topic! Custom furniture for sloped ceilings can be a bit of a challenge, but nothing that can’t be solved with some creativity 😄. I would also recommend using so-called "clamping boards" that you attach to the top of the frame and then clamp under the slope – they hold surprisingly well without damaging the furniture.
Important: always make sure that the load is evenly distributed. Otherwise, the asymmetry will eventually take its toll. And who wants a cabinet that's leaning over the flower bed? 😜
CHENFAR
1 May 2024 10:02
To stabilize IKEA Platsa furniture on sloped ceilings, I recommend the following approach:
- Measure the slope of the ceiling, including determining the angle
- Adjust the back panels of the units, if possible, to achieve full contact with the slope
- Use metal angle brackets screwed to both the unit and the wall
- Add wooden wedges or spacer elements to compensate for the slope
- Secure the furniture to the wall with appropriate anchors, suitable for the wall material
This method significantly improves stability without heavily modifying the furniture itself. Adjustments should be made using suitable measuring tools (protractor, spirit level).
Dustin
1 May 2024 10:28
Quite pragmatically: Use wooden wedges as a base and screw the modules to the back wall. This ensures everything stands securely, even on sloped walls.
blapau
1 May 2024 11:04
koduga schrieb:
I also found it useful to equip the modules on the underside with a baseboard frame to prevent slipping on the slope.
That is indeed a practical tip. Additionally, I recommend attaching profiles made of aluminum or wood cladding along the slope to securely hold the furniture in place. These profiles can both enhance stability and provide an aesthetic adaptation to the incline.
