ᐅ How do I handle the installation of IKEA PLATSA units on sloped ceilings?
Created on: 15 Jul 2024 09:42
kimteHello everyone, I am currently planning the installation of an IKEA Platsa system in a room with a pronounced sloped ceiling and have noticed that the standard assembly instructions offer little guidance for such specific room conditions. My question is: How do I handle the installation of IKEA Platsa on sloped ceilings so that the cabinets are stable, visually well integrated, and make the best possible use of the available space? I am especially interested in which mounting methods are suitable for adapting to the slope, whether special brackets or cutting techniques are recommended, and what I need to consider regarding stability and safety. Has anyone had experience combining Platsa with sloped ceilings or can provide conceptual advice to avoid common pitfalls? Thanks for your support.
The main challenge with sloped ceilings is that the PLATSA modules are actually designed for flat walls and level floors. For optimal installation, I recommend the following steps: - First, accurately measure the slope to customize the modules accordingly. - Adjustments at the top edge are often necessary: you can either trim modular cover panels or arrange the furniture so that the top cabinet fits under the slope. - For stability, be sure to use the supplied wall brackets and, if needed, reinforce them with additional brackets. - If possible, assemble and align the components on the floor before installation. - Lower modules or alternative placements work well for areas under the slope to avoid unused gaps. These measures lead to a more stable construction and an aesthetically pleasing integration of the furniture surfaces.
Nathanaelk15 Jul 2024 10:29The question of installing IKEA PLATSA units on sloped ceilings is technically challenging and requires careful planning as well as specific modifications. I recommend starting with a detailed measurement of the slope, including angle deviations and the maximum available height at different points. Without precise dimensions, any attempt to fit modules to the slope will result in unsightly gaps or stability issues. Important points to consider are:
1. Cutting the top cover panels of the PLATSA system with a jigsaw or orbital sander (depending on the material) parallel to the slope. It is essential to ensure a smooth cut surface to guarantee secure attachment and a clean appearance.
2. Using angle brackets or metal corner braces on the vertical edges to increase stability and reduce the risk of tipping. This is especially crucial for freestanding cabinets.
3. For fixed wall installations, it is advisable to use specialized heavy-duty anchors to ensure that the hanging module construction remains securely attached to the sloped wall over time.
4. Avoiding module rows that end halfway up the slope; instead, adjust by combining lower modules, since small gaps can be visually concealed using trim strips.
Before I provide more details, I am interested in: How steep is the slope exactly, and how much vertical space is available? This information will help recommend the appropriate customizations accurately.
Nathanaelk schrieb:
I'm interested: What exactly is the pitch of the roof, and how much vertical space is available? Good question, thanks for asking! The pitch is about 35 degrees, with a minimum clear height of 1.10 meters (3 ft 7 in) directly under the slope, which then increases. The overall ceiling height is 2.30 meters (7 ft 7 in). The idea is for the PLATSA area to mainly extend along the slope up to a height of about 1.90 meters (6 ft 3 in). I have also considered a combination of lower and higher units to keep the layout as flexible as possible.
warrenka5715 Jul 2024 11:40I had a similar project with PLATSA under a sloped ceiling and can say from personal experience: definitely allow some margin for adjustment in case the connections don’t fit perfectly. My advice is to first assemble the system without fixing it in place and adapt all the parts on site. Especially at the upper edge of the slope, some additional work with a random orbital sander may be necessary.
Also make sure to use the limited height under the slope effectively, for example with open shelves or small boxes if cabinet doors are problematic due to the angle. My impression is that the modules look best when you stagger the heights.
Additionally: safety comes first. Always secure the units to the wall, even though screws can be more difficult to install on a sloped ceiling. In my case, wooden backing plates between the wall and the wall plugs were very helpful.
