ᐅ How can I modify BILLY shelves to make them child-friendly without compromising their stability?
Created on: 10 Feb 2018 14:23
MEONI64
Hello everyone, I have some IKEA Billy bookcases at home and would like to modify them to be more child-friendly without compromising stability. The shelves should be as tip-resistant as possible and free of sharp edges or any hazardous elements for children. At the same time, I need the storage space and don’t want to lose the typical advantages of the Billy system. I’m especially interested in methods or materials you would recommend to make the bookcases safe for small children—for example, installing doors, using edge protectors, securing against tipping, and so on. It would be great if you could also share practical experience or proven DIY solutions. Thanks in advance!
MEONI64
11 Feb 2018 10:22
kulau schrieb:
For child safety, edge protection all around is recommended: soft plastic profiles that can easily be cut and glued on.
Thank you, kulau, that sounds very well thought out and professional! I have two boys, aged 3 and 5 years, who are quite energetic. I really like the idea of reinforced back panels; I hadn’t thought of that before. Are there specific furniture anchors you would recommend, or is the standard model from IKEA sufficient? Also, I’m unsure whether the sliding doors on BILLY are straightforward to install. Any tips on mounting them or extending the side rails?
BAUEVA
11 Feb 2018 11:44
MEONI64 schrieb:
Are there any special furniture anchors you recommend, or is the standard model from IKEA sufficient?
The standard model from IKEA usually works well, but its effectiveness depends heavily on the wall type. Drywall requires different anchors than masonry or concrete walls. Additionally, you should check if the screws are long enough to ensure a secure hold. Generally, these anchors are designed to prevent tipping rather than to increase the shelf’s load capacity.
MEONI64 schrieb:
Sliding doors on BILLY are easy to implement.
Installing sliding doors on BILLY is technically possible, but IKEA does not offer this as an official accessory. Therefore, it requires custom modifications, such as fabricating tracks or using sliding door kits that need to be assembled. This can require professional tools and experience. For beginners, I recommend simpler door systems like soft-close hinged doors or covers that are easy to attach. Adding door hardware can sometimes reduce stability because it puts extra stress on the shelves. However, if you follow the manufacturer’s guidelines and avoid overloading the shelves, it is usually not an issue.
ritotar
11 Feb 2018 12:15
BAUEVA schrieb:
For non-professionals, I recommend simple door systems instead, such as soft-close folding doors or covers that are easy to install.
I always find too much technology distracting when it comes to children’s rooms. I prefer simple, practical, and safe solutions – a combination of furniture anchors, corner guards, and a few magnetic child safety locks has really worked well for us. And believe me, once the kids get older, the doors will soon be left open voluntarily 🙂
