ᐅ How can I modify BILLY shelves to make them child-friendly without compromising their stability?
Created on: 10 Feb 2018 14:23
MEONI64
MEONI64
10 Feb 2018 14:23
Hello everyone, I have some IKEA Billy bookcases at home and would like to modify them to be more child-friendly without compromising stability. The shelves should be as tip-resistant as possible and free of sharp edges or any hazardous elements for children. At the same time, I need the storage space and don’t want to lose the typical advantages of the Billy system. I’m especially interested in methods or materials you would recommend to make the bookcases safe for small children—for example, installing doors, using edge protectors, securing against tipping, and so on. It would be great if you could also share practical experience or proven DIY solutions. Thanks in advance!
Luchen
10 Feb 2018 14:51
I have always used furniture anchors on my BILLY shelves. Securing the shelves to the wall effectively prevents tipping. For sharp edges, there is self-adhesive plastic edge protection, simple and safe.
ritotar
10 Feb 2018 15:32
Hey, I also think that furniture anchors are the best investment! 😄 They keep shelves stable like a bodyguard preventing tipping. For sharp edges, there are really soft edge protectors made of silicone or foam, which not only keep little fingers safe but also look quite discreet 🙂 If you want to add little doors, check out clip-on baby locks – they are child-friendly and don’t cause frustration for parents. Good luck with your project!
Colby42
10 Feb 2018 16:10
That’s great that you want to make your BILLY shelf child-friendly! 🙂 I installed clear acrylic glass guards in front of the open shelf spaces, which protect against bumps while still allowing visibility and preserving storage space. Additionally, this adds stability by supporting the shelves. Maybe this could be an idea for you too!
SETHBLA
10 Feb 2018 16:45
Screw furniture to the wall and install edge protectors – everything else does not provide stable safety. Children learn quickly, unless you want to supervise them constantly.
kulau
11 Feb 2018 09:04
Converting a BILLY bookshelf into a child-friendly version requires both structural modifications and safe surface adjustments. First, I recommend securely attaching the bookshelf to a stable wall using corner brackets or specialized furniture anchors. IKEA also offers suitable accessory kits for this purpose. This significantly improves its tipping stability. Additionally, the back panel of the bookshelf should be reinforced – often the original back is just a thin hardboard sheet, which contributes little to overall stability. Replacing it with a thicker MDF panel or adding a second wooden back panel fixed with extra screws greatly enhances stability.
For child safety, edge protection all around is advisable: soft plastic profiles that can be easily cut to size and glued on. Make sure the adhesive is non-toxic and odorless. It’s best to cover all edges, including those of the shelves. Some people also use foam or silicone sleeves that can be slipped onto the edges. For cabinet doors, I recommend sliding doors as they pose a lower risk of injury compared to hinged doors and avoid issues with misaligned doors. When installing doors or covers, choose sturdy, child-safe locks or magnetic closures.
Another consideration is anchoring on the floor, especially if the bookshelf is tall: rubber feet with anti-slip properties can help, but fixing it securely to the wall is most important.
Which approach are you planning to take? Also, what exact age are the children? That influences several factors.
