ᐅ What is the typical load capacity of Billy bookcases?
Created on: 5 Aug 2020 18:03
Rebuus
Rebuus
5 Aug 2020 18:03
I am currently planning to reorganize my home office and have been considering the Billy bookcases from IKEA. However, I have a very specific question: What is the typical load capacity of Billy bookcases?
I am particularly interested in the maximum weight per shelf and for the entire unit under normal everyday conditions, such as when storing books, binders, or somewhat heavier items.
Additionally, I would like to know if there are common weak points that tend to become problematic when loading, and whether certain measures (e.g., additional bracing or shelves made from different materials) can noticeably increase the load capacity.
I would really appreciate detailed information and experiences, including any advice on what to avoid in order not to overload or damage the bookcases.
Thank you in advance!
TEBILO
5 Aug 2020 18:25
Hello Rebuus,
Regarding your question: The average load capacity of a Billy bookcase really depends on the specific model, its size, and the type of shelves used. For the standard model (80x28x202 cm (31½x11x79½ inches)), IKEA typically states a maximum load of around 30 kg (66 lbs) per shelf.
However, this value is based more on static load tests under ideal conditions. In practice, it also depends on how evenly the weight is distributed. For example, if you place many books with sharp edges that apply point loads, the shelf surface may bend more quickly.
Typical weak points are the shelves themselves, which rest on metal supports. If you place very heavy or unevenly distributed weight on them, the shelves can sag quickly and cause long-term damage to the supports. The back panel (usually a thin hardboard) also contributes to stability and should always be firmly attached to prevent side-to-side wobbling.
If you want to increase load capacity: Additional support strips under the shelves or replacing the shelves with stronger wooden boards can help. Also, securing the bookcase to the wall significantly improves safety and stability, as it prevents tipping or wobbling.
How exactly do you plan to load the shelves? With books, files? Or also with equipment or decorative items?
Rebuus
5 Aug 2020 18:48
TEBILO schrieb:
typical weak points are the shelves themselves
Thank you for the detailed response! Yes, the shelves will mainly hold books and binders — so significantly more weight than just decorative items.
When heavily loaded, it is important to me that the shelves not only support the weight temporarily but also remain stable without bending over a longer period. Do you have any experience with whether the shelves tend to sag quickly after a few months or years of full loading? At the same time, I wonder if there are differences between the older and newer models, for example, if IKEA has changed anything in the manufacturing process?
chenfi
5 Aug 2020 19:03
The shelves of the Billy unit can permanently support approximately 25–30 kg (55–66 lbs) if the load is evenly distributed. For heavy books, it is advisable to secure the back panel and additionally fix the shelving unit to the wall.
V
VINKU
5 Aug 2020 19:17
I can only agree with that. It is also important that the metal pins supporting the shelves are properly seated and not bent, otherwise there will be more sagging. Especially if you plan to load the shelf heavily over a long period, you should secure it to the wall. The manufacturer’s specifications are to be seen as a guideline – in practice, the shelf always needs to be well maintained and checked.
A small addition: If you have particularly heavy loads, you can also consider additional reinforcements, such as attaching battens under the shelves. This way, you distribute the load more effectively.
Katan
5 Aug 2020 19:26
Hey Rebuus! 🙂
Billy is kind of a classic – when it comes to load capacity, I’d say the shelves are sturdy but not engineering marvels. Books and folders are fine, but if you start stacking hammers and anvils, things will get tight 😉
A little tip: It’s better to distribute the load evenly instead of putting everything on one shelf. And very important – secure the shelf to the wall. This not only ensures safety but also helps the shelves stay straight for longer.
Good luck with your furniture building! 🙂
