ᐅ How can I make Ikea Metod drawers quieter and smoother to operate?
Created on: 19 Sep 2022 10:37
Rahannes
Rahannes
19 Sep 2022 10:37
Hello everyone, I have a question about my IKEA Metod drawers: How can I make them quieter and smoother? I’ve noticed that they are quite loud and sometimes a bit jerky when opening and closing, which can be especially noticeable in quiet moments at home. Are there any proven methods to improve their smoothness and closing behavior—such as specific adjustments, soft-close mechanisms, lubricants, or other tricks? I’ve done some research already but I’m hoping for your practical experiences and tips tailored specifically to the Metod series. Thanks in advance!
glapu
19 Sep 2022 11:02
Hi, I would first completely remove the drawer slides and clean them. Then apply some silicone spray or general-purpose grease to the runners. This reduces friction and makes them quieter. Also, be sure to check if the drawer is properly aligned – sometimes it only sticks due to incorrect adjustment.
GLALEO
19 Sep 2022 11:47
Great question, Rahannes! 😃 I find this topic really interesting because soft-close drawers greatly improve the overall kitchen experience! 💪 My recommendation: definitely check if your drawers have soft-close mechanisms. This is now standard with Metod, but sometimes the dampers don’t work properly anymore. Also, a bit of patience when adjusting them helps – and silicone spray is truly a lifesaver! Good luck, you’ve got this! 🚀
Jeanbar
20 Sep 2022 09:15
Hello Rahannes, I’m happy to explain this in more detail: IKEA Metod drawers usually have integrated soft-close dampers that slow down the closing action gently and help reduce noise. If this is not working properly, it could be due to the following factors:
- Dirt or dust in the slides
- Missing or hardened lubricants
- Misaligned drawer slides or drawer fronts
I recommend the following steps:
- Remove the drawer and clean all components thoroughly
- Treat the slides with an appropriate lubricant (silicone spray or dry lubricant)
- Check that all screws are tight and that the drawer front and cabinet are properly aligned
If the dampers are broken, they can be replaced, but IKEA offers limited spare parts for these – so it might make sense to replace the entire drawer slide system. If needed, I can also provide a step-by-step guide.
Siflo
20 Sep 2022 09:47
Jeanbar schrieb:
IKEA Metod drawers usually have integrated soft-close dampers that slow down the closing motion gently and help reduce noise.
That is correct. Additionally, I recommend using high-quality silicone or PTFE spray on the drawer slides to minimize friction. At the same time, it should be checked whether the drawer runners are properly installed and aligned parallel to each other. Mechanical defects or bent runners increase noise and impair smooth operation.
Regular cleaning also helps reduce dirt buildup, which can cause rough opening and closing.
Trate47
20 Sep 2022 14:09
Looking at it casually: who doesn’t love a drawer that closes so smoothly you barely notice it moving? 😄
My soft tip: check and adjust more often. Sometimes just a small turn of the screwdriver is enough to realign the drawer front, and suddenly it glides like butter. Also, I find that silicone spray works almost like magic after cleaning! And if you’re feeling adventurous, try using those small soft felt or rubber strips on contact surfaces to reduce vibrations – it sounds fancy but is really pleasant, especially in the kitchen.
