ᐅ How can I increase the load-bearing capacity of Ikea PLATSA shelves?
Created on: 9 Aug 2016 08:37
gijsteo
gijsteo
9 Aug 2016 08:37
Some time ago, I bought an Ikea Platsa shelving system, which I generally like a lot, but I have encountered an issue that I would like to fix: the load capacity of the shelves is clearly limited—especially when I store heavier items like books, binders, or electronic equipment on them. I am therefore specifically interested in practical and feasible ways to increase the load-bearing capacity of the PLATSA shelves without significantly changing the appearance or extensively modifying the furniture.
Are there, for example, recommendations for additional reinforcements, better materials, or alternative installation methods that could improve the load capacity? Also, any information on how much weight Ikea typically rates the shelves for would be very helpful, so I can realistically assess the situation.
I look forward to your tips and experiences!
Garry
9 Aug 2016 10:42
Hello gijsteo,
First, regarding the load capacity of Ikea PLATSA shelves: Ikea usually states the maximum load in the product description, which is often around 15-25 kg (33-55 lbs) per shelf, depending on whether the material is particleboard or something else.
To increase the load capacity, here are some proven methods:
- Reinforcement with additional metal or wooden profiles underneath the shelf board, for example aluminum rails or strong battens, which can be glued or screwed to the underside
- Installing support legs under the shelves or inside the enclosed shelving unit to reduce the span
- Using stronger shelves made from plywood or multiplex as replacements for the original shelves, although this often requires adjustments
It is important that the reinforcement is applied evenly and the construction remains within the framework of the Ikea modules so that stability is not compromised in other ways. Especially for heavier loads, support legs or additional vertical profiles are highly recommended.
It may also be sensible to distribute the load across the entire height of the shelving unit, rather than heavily loading only individual shelves.
Hope this helps as an initial guide.
Lenfa
10 Aug 2016 19:26
Garry schrieb:
Reinforcement with additional metal or wooden profiles under the shelf board,
Hello gijsteo,
I would like to explain the options in more detail so you have a good overview.
PLATSA shelves are usually made of particleboard, which can bend under heavier loads, especially with wider shelves without a center support. To increase the load capacity, you can consider the following:
- Additional cross braces: Metal brackets or wooden strips fixed to the underside of the shelves increase rigidity and prevent sagging.
- Use center supports: If your shelving system is tall, you can install a vertical center support made of wood or metal that carries the shelf in the middle. This is particularly helpful for wider shelves.
- Replace with stronger shelf boards: Many furniture or hardware stores offer specially reinforced shelves made of plywood or MDF that can be cut to size. These are significantly more durable than standard particleboard.
- Use shelf brackets with stronger anchoring: Sometimes the included shelf supports are not suitable for heavy loads. In this case, stronger fasteners or additional brackets can help.
- Visually discreet: If appearance matters, you can paint the reinforcements on the underside of the shelf in a matching color or cover them with veneer.
- Avoid point loads by distributing heavy items evenly or using boards as additional base plates.
If you like, I can also mention common mistakes I often see in such projects, for example, spans that are too long without support or using cheap screws that loosen over time.
Would you like me to cover that?
Good luck with your project!
roman36
11 Aug 2016 07:51
Lenfa schrieb:
Install center supports: If your shelving system is tall, you can install a vertical center support made of wood or metal,
Simply adding center supports and thereby halving the shelf width is usually the most effective solution.
Garry schrieb:
Using stronger shelves made of multiplex plywood or plywood as a replacement
Alternative shelves made of multiplex plywood significantly increase stability. That was also implemented in my case.
If the shelving is fixed to the wall, you can carry more load through direct attachment as well.
