ᐅ Are there any recommendations for using solid wood furniture instead of particleboard with Ikea PLATSA?
Created on: 20 Mar 2024 09:27
sijatarGood morning everyone,
I recently came across the Ikea Platsa system and am considering using it for my storage solution. However, I am bothered by the use of particleboard in most components, as I prefer solid wood for stability and environmental reasons.
Does anyone have recommendations or experience with solid wood furniture that is compatible with PLATSA, or perhaps retrofit solid wood components for PLATSA?
I would like to know if the quality and durability of solid wood really offer advantages here, or if I have to accept compromises, for example in terms of weight, price, or ease of handling.
I appreciate any insights, especially if you have already combined solid wood furniture with PLATSA or know where to find such alternative solutions.
Thank you in advance!
Hi!
Particleboard is actually the standard material at Ikea, but I understand that you prefer solid wood – it just feels more premium and also has a better environmental footprint.
Unfortunately, there are no official solid wood alternatives for PLATSA at Ikea, but here’s what you can do:
- Buy the PLATSA frames and then add solid wood elements inside
- Look for alternative furniture with solid wood from other manufacturers and combine those with the PLATSA modules
I’ve tried something similar myself: I replaced the standard doors with third-party CPL fronts, which gives a somewhat more natural feel.
Just be careful, because solid wood is heavier and less flexible than particleboard. Sometimes you’ll need stronger fixings as a result.
Good luck with your combination – such an upgrade will definitely make it look even better!
Hello sijatar,
I would like to provide a technical perspective on this topic: Ikea PLATSA mainly uses particleboard with a melamine coating to achieve a good balance of weight, stability, and cost. Solid wood, on the other hand, behaves differently in several ways:
- Weight: Solid wood is significantly heavier and requires stronger fasteners.
- Workability: Particleboard is lighter and more uniform, while solid wood can warp, which could be problematic for prefabricated built-in systems like PLATSA.
- Compatibility: The connection points, mounting holes, and locking systems of PLATSA are not designed for solid wood. Retrofitting usually requires custom craftsmanship.
If sustainability is your priority, you might consider products made from certified particleboard or plywood with FSC/PEFC certification instead of solid wood. While these are not solid wood panels, they are more environmentally friendly than conventional particleboard.
How exactly do you plan to use the solid wood components? Are you planning to have replacement panels made, or are you looking to remodel entire pieces of furniture?
Dilen schrieb:
If sustainability is important to you, you might consider using products made of certified particleboard or plywood with FSC/PEFC certification instead of solid wood. That's an interesting point, thanks! Basically, I want to stick to the idea of solid wood as much as possible because I believe it is more durable and also performs better in terms of harmful substances.
My idea was rather to replace the back panels and cladding with solid wood cut to the right dimensions or at least parts of them. I would keep the supporting frames from Ikea, as making solid wood to precise measurements by hand is a challenge, especially regarding the joint details.
Is there anyone here who has worked with plywood or solid wood to replace particleboard in modular furniture? How do the stability and durability of the screw connections compare?
I appreciate that you formulated the question in such detail and with a clear objective.
Regarding the topic: It is often claimed in various forums that solid wood is automatically more durable and better than particleboard. This needs to be considered more carefully.
Particleboard with melamine laminate may not be as high-quality as real solid wood, but it offers a consistent material density that keeps joints stable. Particleboard can also be extensively treated to resist moisture and pests.
Solid wood is naturally variable and reacts to changes in humidity and temperature. This can lead to fitting issues in prefabricated systems like PLATSA.
I would recommend taking a closer look at the load requirements of the furniture. For example, if you need to support heavy loads, solid wood can sometimes be better; for lighter use, particleboard may be entirely sufficient.
Additionally, the ecological assessment of particleboard is not necessarily worse—recycling processes are constantly improving, and the carbon footprint depends not only on the material but also on transport and production.
Therefore, evidence supporting these claims is important before regarding solid wood as the ultimate choice.
Josefane schrieb:
Chipboard can be treated with specialized impregnation to resist moisture and pests.That's true, especially for kitchen and bathroom furniture, chipboard can sometimes be surprisingly durable.
I just wanted to add: if you use solid wood, it also offers a different visual experience – the charm of solid wood appeals to many, and especially for visible parts, it's a real advantage.
Of course, careful planning is necessary, particularly regarding weight and how the surfaces should be finished.
And I can only recommend experimenting a bit with the Ikea system, possibly trying different fronts or inserts.
