ᐅ Floor Plan Design for a 150 sqm Single-Family Home – Tips for Improvement?
Created on: 22 Jan 2019 13:30
Franky73
we are in the process of building a single-family house with a basement suitable for living. This is the design we have come up with. I would like to hear from you if you see any possibilities for improvements.
On the ground floor, there is a side entrance door on the right. The carport will be located there.
In the basement living area, the children's rooms face south. From there, it should be possible to access the terrace and the garden.
I look forward to your tips and suggestions!
Franky73 schrieb:
What exactly do you want me to explain??? You need to be more specific about what you like and don’t like about your floor plan. What is a "must-have" and what could be changed? Otherwise, you could just keep your last floor plan as it is and be done with it. So, what bothers you about it?
You mentioned you’d like an open staircase to prevent the hallway from feeling too bulky. That’s how I understood it at least. With my last suggestion, I was mainly focused on the size and furniture layout of the living room. But it seems you prefer your current floor plan instead.
The "parent’s area" also forms a unit with its own door. Is that good for you, or don’t you like the arrangement of bedroom, bathroom, and dressing area?
And so on.
Come on, tell me a bit more. Keep in mind what it will cost you—that usually helps keep you motivated.
Optimization is successful when you start out willing to change everything, and the result accidentally ends up very similar to the original model – not when setting out with the goal to change only a little.
Just a pocket-sized Confucius saying
kaho674 schrieb:
Tell me a bit, come on, come on. Just always keep in mind what it will cost you. That’s motivating. - Small guest toilet on the ground floor
- Bathroom 10-12 sqm (108-129 sq ft) with an open shower without glass screen or threshold strip
- Bedroom with the current dimensions in my draft would be sufficient
- Walk-in closet for two 1 - 1.5 meter (3.3 - 5 feet) units (minimum 2 meters - maximum 3 meters total for wardrobe units)
- Utility room on the ground floor, if possible with outside access from the carport (but not a must)
- If possible, a small covered area for smokers (my wife and guests). This is not absolutely necessary!
- Bar counter for 3 people to sit at in the kitchen area
- Kitchen in U-shape or two rows
- Exterior view of the house from the front (entrance area) with a few windows as usual, 4 or more, plus a main door element—not just two windows as shown in one draft!
Your desired room layout does not really match the house size. As a result, you have too little space for living and dining.
Perhaps my comments are a bit direct.
Okay
It can also be smaller. Size isn’t everything.
Okay
Why a walk-in closet? That’s not much closet space. You won’t find a floor plan with your planned house size that includes a walk-in closet.
Why on the ground floor? It doesn’t hurt to have the fuse box and such upstairs.
I can understand that. I wouldn’t want it in front of the bedroom.
Why? The dining table is just a few centimeters (inches) away.
I would relocate building services upstairs. Remove the walk-in closet. Make the bedroom a bit larger. Bathroom about 10m² (107 sq ft). Pantry for the washing machine later. Kitchen with two rows, no bar counter.
Okay
- Bathroom 10–12m² (107–129 sq ft) with an open shower without glass wall and T-divider
- Bedroom dimensions in my current design would be sufficient
Okay
- Walk-in closet for two 1–1.5m (3.3–5 ft) units (min. 2m – max. 3m (6.6–9.8 ft) total for closet modules)
- Utility room on the ground floor, if possible with outside access from the carport (but not mandatory)
- If possible, a small covered area for smokers (my wife and guests), but this is definitely not a must!
Franky73 schrieb:
Now I am curious! Which of your essential requirements does my suggestion fail to meet if you turn the pantry into the utility room? The same applies to your current floor plan. Do you understand the issue?Personally, I also find your wishes too much for the ground floor. Even though your house is over 12m (39 feet) wide, all the rooms are very small (except for your bathroom). It always feels like living in a 60m² (645 square feet) apartment. Is that what you want?
