ᐅ Experiences with Ground Source Heat Pumps
Created on: 23 Oct 2015 21:40
Saruss
here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Musketier8 Feb 2017 11:31
@BeHaElJa
Where did you get your temperature values from?
Saruss
9 Mar 2017 22:07
February 2017
226 kWh
Heating degree day total 440
DerUnbeugsame
14 Aug 2017 11:43
Hello everyone, I have been a happy homeowner for one year now with a Novelan S/W heat pump, 2 x 99.5 m (327 ft) probes, and a 9.2 kWp photovoltaic system, and since then I have had zero heating or electricity costs. On the one hand, I am amazed at what is already possible today, and on the other hand, I am equally shocked at how companies take advantage of people’s lack of knowledge with misinformation and the obstacles put in place by the government and energy companies.
Saruss
14 Aug 2017 11:47
How do you manage that in winter? Or do you overall break even because the income in summer, when the heat pump isn’t running, offsets the costs in winter? (Although using the energy yourself is financially better than selling it?) For me, 9 kWp would probably be just enough, since the summer income would hardly cover the full costs in winter, but the ongoing expenses would already be lower.
DerUnbeugsame
14 Aug 2017 11:54
I finance this through a surplus calculation. From spring to autumn, I produce five times the amount of electricity I consume in winter. The money I earn from the surplus electricity in spring, summer, and autumn is then used in winter to buy the electricity I need. I receive 12.3 cents per kWh but have to pay 29 cents per kWh when purchasing electricity. The money left over in spring is my profit, which was 590 € in the first winter.
Gatho
14 Aug 2017 15:37
Hi!
How often do you run the anti-legionella program on your system?
With our Waterkotte EcoTouch Ai1 Geo, the longest interval you can set is once a week – is that really necessary? I wanted to ask how you manage this with your systems.
What temperature do you use? I currently have it set to 65°C (149°F).
Good luck & thanks
