ᐅ Experiences with Ground Source Heat Pumps
Created on: 23 Oct 2015 21:40
Saruss
here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Sebastian79
31 Dec 2015 18:32
Measured with the internal depth gauge?
Having more length than necessary doesn’t really give you a huge advantage... just so you don’t overestimate it.
We also had an issue with this – I wanted the thermally optimized injection material, but that wasn’t properly applied. Well, can’t change it now...
MeisterBob
31 Dec 2015 18:35
I’ll give you the latest update through Sebastian tomorrow, have to head to the party now.
Legurit
31 Dec 2015 18:42
The heating system has a capacity of 5.3 kW. Originally, 100 meters were supposed to be drilled, based on a rate of 50 W/m. However, during the Lbeg test, we found that only 40 W/m can be achieved in our case. We then adjusted the calculations accordingly and added a few extra meters, resulting in a 6.3 kW borehole. That’s why I’m a bit puzzled that the brine temperature is so low compared to others.
Sebastian79
31 Dec 2015 18:51
Who knows how precisely it was set, and what brine concentration you have...
Legurit
31 Dec 2015 19:22
When in doubt, go with the drilling company. The brine is also included on the invoice; however, of course, it may not be comparable.
Saruss
31 Dec 2015 20:29
I think it’s also important how well the temperature is maintained in the long term. If it doesn’t drop too much after one winter, that should be fine.
