ᐅ Experiences with Ground Source Heat Pumps
Created on: 23 Oct 2015 21:40
Saruss
here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Sebastian79
1 Sep 2016 07:08
Yes, of course....
Legurit
2 Sep 2016 10:18
August
4 people, 190 sq m (2045 sq ft) living area, KFW55 Energy Saving Ordinance 2014
Heating: 3 kWh electricity (I believe one of these was due to a failed cooling attempt)
Water: 26 kWh electricity
Household electricity: 136 kWh electricity
Legurit
2 Sep 2016 10:24
I can only give you an average water consumption… 62 m³ (2189 cubic feet) since mid-February, so roughly 10 m³ (353 cubic feet) per month.
I have set the heating to run for 30 minutes in the morning. 180 L (48 gallons).
Yes, I read the heat pump’s data – but I also check the meters. On July 31, the heating submeter showed 5412.68 kWh and on September 1, 5442.02 kWh. At the same time, I also read the main meter.
Sebastian79
2 Sep 2016 10:31
OK, she is allowed to heat whenever she wants and for as long as she wants – I’m still not sure how to regulate that exactly...
She uses 2 kWh per day for this – according to colleagues, that's completely fine. It’s 400 liters (about 105 gallons), but that amount isn’t needed every day. However, showers generally last longer, and she heats up again shortly after showering.
The temperature is set to 47°C (117°F) with a hysteresis of 9°C (16°F).
Sebastian79
2 Sep 2016 10:45
Of course, the tank loses heat – who says otherwise?
The other day, I insulated all the exposed connections.
Legurit
2 Sep 2016 11:06
The Vaillant technician who conducted the inspection for the warranty said that the heat loss was minimal and that the tank can store its heat for 2 days... as if.
