ᐅ Experiences with Ground Source Heat Pumps
Created on: 23 Oct 2015 21:40
Saruss
here I would like to share some experiences and data regarding my brine heat pump and deep drilling, based in part on the expert’s "questionnaire":
a) What is the soil composition on your property?
Up to 3m (10 feet) silty, fine sandy, clayey soil
Up to 4m (13 feet) slope debris, rock fragments
Then bedrock (mainly limestone)
b) How deep was the drilling?
Drilled twice to a depth of 72m (236 feet)
c) How much did the drilling cost?
€10,400 including double U-probes DN25
Grouting material with 2.0 W/mK thermal conductivity
Permitting process (building permit / planning permission)
Pressure-tight house entry at the basement and underground routing of supply lines (about 25m (82 feet))
Filling/draining equipment, filling, pressure testing, etc. (all inclusive)
d) How much did the system cost?
System: Tecalor TTc 05 with heating output at B0/W35 of 5.8 kW and coefficient of performance (COP) of 4.8
Cost: €9,800
e) Were there any difficulties during installation, if so, what kind?
Because the water used to flush out the drilled material during drilling seeped away, a "small compressor" was needed to blow it out with air. However, it had to be placed on a neighbor’s property who had not yet started building. The machine was the size and approximate weight of a 20-ton truck but was off-road capable. This caused a 2-day delay because the compressor first had to be transported to our site. No additional costs were charged.
f) How is the daily operation?
"Like a refrigerator." Once the parameters on the heating system are correctly set, the only thing that should be done is occasionally reading the information/data such as operating hours and source temperature. Otherwise, it runs "on its own," just like any heating system. When the door is closed, the unit is virtually inaudible. Very discreet since, apart from the cabinet in the utility room, nothing else is visible (all brine pipes are underground).
e) What are the operating costs for which living area?
Currently, a living area of 180sqm (1937 sqft) is heated, plus an additional 65sqm (700 sqft) of cellar space within the insulated thermal envelope (these rooms are around 15-16°C (59-61°F) on the coldest days). From September 2014 to September 2015, 2,000 kWh of electricity was consumed for heating and hot water (2 adults, 1 baby, 1 toddler). The house is a KfW-70 standard building according to the 2009 energy saving regulations, which already met the required technical standards before the central ventilation system with enthalpy heat exchanger was installed (we decided to add this after the initial applications).
f) to be continued ....
Note regarding the comparison of the coefficient of performance (COP):
Since optimizing the heating curve and settings at the end of last year, the system has had a COP of about 5.5. Operating hours are around 1200; the deep borehole was drilled approximately 20% deeper than initially recommended by the companies, at our own request.
Saruss
9 Nov 2015 21:18
You mean screed heating? That depends on many factors—outside temperature, the mass of the screed, type, insulation, heating curve/time, and so on. In our case, it was about 2300 kWh of HEAT. It wasn’t very cold outside, I think around 10°C (50°F). Depending on the COP, which is usually moderate, the warmer it is, the lower the electricity consumption—around 550 kWh of electricity, or more or less, depending on the construction project, with a heat pump.
djon25
9 Nov 2015 21:24
Exactly.
In our case, the construction phase would be in the summer, so it will likely be warmer than 15°C (59°F). Alright, as a reference value, I will assume 550 kWh.
We were told that costs of 1400–2200 EUR would easily occur.
Thank you
toxicmolotof
9 Nov 2015 23:15
Is the heat pump even capable of this? Heat pumps are generally not designed for these amounts of energy. Costs of around 1000–1500 euros can definitely occur if a separate instantaneous water heater is used.
Saruss
9 Nov 2015 23:25
We already had a similar question yesterday. Apart from the initial ramp-up, it is possible. A brine heat pump can easily maintain a house’s temperature at -15°C (5°F) without an auxiliary heating element, so why wouldn’t it be able to raise the temperature from 15°C (59°F) to 30°C (86°F) (a smaller difference)?
Legurit
9 Nov 2015 23:27
We were told that it’s better to use the heating rod for dry heating… which works well for us since the borehole isn’t finished yet. We should expect costs of around 600 € (about 650 USD). I can report back later on what the final cost actually was.
I’m not entirely sure if warm outdoor temperatures are really beneficial — I would rather say no. It’s better if it’s nicely cold outside, so you bring in cold air, warm it up and saturate it with moisture, then ventilate to let in fresh cold air again. The building components don’t cool down that quickly. That’s how I understand it.
Saruss
9 Nov 2015 23:32
I’ve heard that the weather machines are fully booked. Otherwise, you’re right—cold (preferably dry) air is best for drying. Just not too fast when it comes to screed, as it needs to cure, not dry out, and for that it requires some moisture for a while.
