Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
11ant8 Dec 2021 14:41
Tom1978 schrieb:
The foundation slab is clearly visible.
Oh, the blocks are from Eder – does that include the Pumuckl?
I think they’re a bit awkwardly placed there: you have to move them first before you can start building the walls.
motorradsilke
8 Dec 2021 14:48
Tom1978 schrieb:
You're right :-) I'll go there again 🙂
I would seal those properly as well. Otherwise, they won’t last long, and you’ll end up with dirt inside during construction.
Tom1978
8 Dec 2021 15:28
Oh, the bricks are from Eder – does that include the Pumuckl?
I think they look a bit awkward there: you have to move them first before you can start building the walls.
I don’t have to do any bricklaying 😎 And yes, Pumuckl is included. All the shell builders must be red-haired...
motorradsilke schrieb:
I would seal them properly. They won’t last long like that, and you’ll end up with dirt inside while building.
My wife said the same. Strange, should I be worried? 😎
motorradsilke
8 Dec 2021 15:39
I wouldn’t worry, nothing has happened yet.
In our case, all of them were properly sealed. During construction, a lot of debris is generated, and you don’t really want that inside the pipes because it’s difficult or even impossible to remove later.
If the general contractor doesn’t do it, I would take care of it myself.
TmMike_2
8 Dec 2021 18:47
K1300S schrieb:
Guys, seriously: Do you really think a construction fence can prevent theft even remotely? Its main purpose is liability and to keep passersby away from hazardous areas. For anything else, you need other measures like a construction watch.
I’m not familiar with the legal situation.
But overcoming a construction fence or breaking a lock might qualify as aggravated theft, which leads to harsher legal consequences.
There could also be insurance reasons for it.
Although many don’t take out insurance anymore because it has simply become too expensive.
Insulation wool, XPS, wood, and polystyrene are in short supply.
But why would anyone steal bricks? (Effort vs. benefit)
You’d need a 40-ton truck with a crane attachment to load everything.
People are more likely to load a 500 kg (1100 lbs) compactor into a 3.5-ton (3.9 US ton) van and be gone in 5 minutes...
However, my building materials supplier confirmed that during the peak of the supply crisis, entire external thermal insulation composite systems (ETICS) were ripped off the facade and stolen.
“Why should the customer wait when Hassan has a contract for 20,000 cash but no materials available — you need a solution”
- so much for that topic
Radomiro
8 Dec 2021 18:54
No, actually, they are inside the rooms, and the walls are built around them.
Regards
