Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
K1300S7 Dec 2021 12:09
Guys, seriously: Do you really believe that a construction fence can prevent theft even in the slightest? It is primarily about liability and keeping passersby away from hazardous areas. For everything else, other measures like construction site surveillance are needed.
Tolentino7 Dec 2021 12:13
Sure.
Insurance companies usually want to pay out as little as possible and therefore require a secured construction site. Everyone knows that a construction fence won’t actually stop anyone.
It’s the same with a maintenance contract for flat roofs. The roofer hired for this will not provide a warranty for concealed defects (which are almost always hidden), but the building insurance will only pay out if you can prove that regular maintenance was carried out.
DIY photos are not sufficient proof (even though they serve the same purpose as the roofer just checking once), but a professional contractor’s report is accepted.
It’s almost always just about appearances.
11ant7 Dec 2021 12:15
Mahri23 schrieb:
Did you secure your construction site with some kind of building fence? [...] The friendly neighbors kept a watchful eye on the site.
With all the bird and bat boxes around, a few cameras probably wouldn’t stand out at all 🙂
Tom1978
8 Dec 2021 05:54
Here are a few more pictures. The concrete slab is clearly visible.
Construction site: concrete foundation with stacked EDER brick pallets, forest in the background.
Construction site: stackable building material packages with EDER logo on concrete slab, surrounded by soil.
Construction site with pink insulation boards on foundation slab, forest in the background.
Mahri238 Dec 2021 10:20
@Tom, rain is getting into an open pipe... 😀
It’s already looking good. When will they start the masonry work?
Tom1978
8 Dec 2021 10:25
Looks pretty good already. When will they start the masonry work?
You’re right :-) I’ll go there again 🙂
Masonry depends on the weather. The plan is for January 10, 2022.
