Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
motorradsilke24 Nov 2021 14:05I find it interesting that the foundation and the slab are two separate parts. And that they are also constructed on different days.
It was the same for me. Apparently, the ground slab is not necessarily a load-bearing structure (don’t ask me how that works).
In any case, I was told at the “shopping center around the corner” that while this is structurally possible, it reveals a very low-cost construction method.
I can’t say much more about it, except that the experts there are quite elitist and tend to favor high-end construction methods (not necessarily in terms of price, but regarding technical standards).
My building inspector did not have any negative comments about it.
motorradsilke24 Nov 2021 14:16For us, it is one piece. Whether this is technically better one way or the other, I’m not sure. I would have thought it is always done this way because it is probably more cost-effective.
The gravel being used here was called fill sand in our area. According to the earthworks contractor, it can be compacted to the required standard and is load-bearing enough for an entire house. For example, trench walls do not collapse.
For our 16 x 10 m (52 x 33 feet) slab, the strip footing and slab were poured in one continuous process, without any steel mesh reinforcement, using fiber-reinforced concrete.
Nida35a schrieb:
Strip foundation and slab poured in one go, Was it the same general contractor as well?
For us, they were done separately!
