ᐅ Is it possible to retrofit lighting in a Pax wardrobe?
Created on: 12 Aug 2016 13:17
Jarle
I have a question that has been on my mind for a while and I’m hoping for your advice: Is it possible to retrofit the IKEA Pax wardrobe system with integrated lighting—not just the usual stick-on LED strips, but a permanently installed lighting solution built directly into the wardrobe?
I’m referring to a technically clean and durable solution, ideally with its own power connection or operating via the regular electrical supply, and possibly activated by a motion sensor or a switch.
Has anyone done this before or can offer tips on what options are available, how complex such a retrofit is, and whether it requires modifications to the cabinet structure?
Thanks and best regards!
BASTIANTI
13 Aug 2016 09:14
Top topic, Jarle! ? A few months ago, I equipped my Pax with LEDs and a motion sensor, and it feels like a luxury! You can see everything perfectly, and the whole setup looks really neat and well integrated.
Just go for it – with a bit of patience and the right equipment, it works great and is a worthwhile investment! ?
nikian
13 Aug 2016 11:22
Hello Jarle,
if you are planning a fully fixed installation with a power connection, you should consider that the cabinet either needs to be placed near a power outlet or that you run a direct house wiring (concealed or surface-mounted conduit) to the cabinet.
Additionally, the cabinet should be mechanically modified to ensure that no cables are pinched or damaged. It may be necessary to replace the back panel or add a cable opening at the rear.
For motion sensors, there are different options – some are battery-powered, while others require a power connection. This is important to consider during the planning phase.
Teonon
14 Aug 2016 08:29
nikian schrieb:
If you are planning a complete fixed installation with an electrical connection, you should consider that the cabinet should either be placed near a power outlet or that you run a direct house wiring (flush-mounted or surface-mounted conduit) to the cabinet.
Exactly, that is often the most critical point. In my case, the cabinet is close enough to the power outlet, so I only needed an extension cord. However, for a permanent solution, I would definitely hire an electrician. Safety comes first!
There are also very small and discreet motion detectors available, which are inexpensive and easy to install.
sonpar
14 Aug 2016 10:45
Pax can be easily retrofitted with LEDs and motion sensors. Instructions:
- choose suitable LED strips or bars
- provide an opening for cables
- connect power supply
- install motion sensor if necessary
If unsure, contact an electrician.
risar
15 Aug 2016 12:53
Jarle schrieb:
Is it possible to retrofit the IKEA Pax wardrobe system with built-in lighting—not just the usual stick-on LEDs, but a permanently installed lighting system integrated directly into the wardrobe?
To add to this: Besides the LED strips offered by IKEA, there are third-party suppliers that provide lights and motion sensors specifically designed for the Pax system. These often fit the design better and offer higher quality. It is important to always ensure compatibility with the voltage and to follow safe wiring practices.
If you want more details or specific product recommendations, I’m happy to help.
