ᐅ Are there IKEA PAX wardrobes with built-in lighting and power outlets?
Created on: 27 Dec 2023 08:22
talha68
I’m currently wondering if there are any Ikea PAX wardrobes that come from the factory with integrated lighting and power outlets. I understand that PAX systems are usually assembled by the customer and enhanced with accessories, but I’m specifically curious if there are models or sets that include these features built-in—essentially a PAX wardrobe with interior light strips and ideally power strips for electricity supply, permanently installed and working without any retrofitting.
It is particularly important to me whether such options are officially offered or if you are always dependent on third-party products or DIY solutions. If anyone has experience with this or knows of alternatives, I would appreciate a detailed reply.
TRADI
28 Dec 2023 09:31
Hello talha68,
I’m happy to support kaubis’ approach with a few practical tips. Basically, you have two options:
- You can use battery-operated LED strips like "Omlopp," which you attach with adhesive tape to the inside of cabinet doors or walls. They are easy to install and require no wiring, but you will need to replace the batteries regularly.
- The other option is hardwired LED strips such as "NÄVLINGE," which you connect to the power supply using a transformer and ideally combine with a wall switch or motion sensor. For this, you should have an electrician install the outlet inside the cabinet or set up the wiring.
For the outlet inside the interior of the Pax cabinet: yes, there are special corner power strips or flat under-cabinet outlets that can be well concealed. Just make sure the wiring is properly protected and professionally installed.
This way, your cabinet will look tidy, and you’ll gain real added value through lighting and the outlet.
Feel free to ask if you have any questions.
meoreo
28 Dec 2023 11:08
TRADI schrieb:
If you have any questions, feel free to ask again.
I would like to add that motion sensors for lighting are very useful, especially in the bedroom. They save electricity and provide convenience.
loken
28 Dec 2023 14:22
Hey talha68,
from what I see, you will need to opt for a proper retrofit with PAX. But that’s not a problem at all! I once fitted a cabinet with LED strips from Ikea and hid the power strips using cable ducts. It looks great and works perfectly.
My advice: check out "OMLOPP" for a simple lighting option and "NÄVLINGE" for fixed wiring. For the sockets, you can use flat modules that just need to be screwed or glued in. Motion sensors, as meoreo mentioned, are a great feature, especially if you need something at night without turning on the main light.
Good luck and feel free to reach out if you want!
talha68
29 Dec 2023 08:11
loken schrieb:
My tip: Check out "OMLOPP" for a simple lighting option and "NÄVLINGE" for fixed wiring.
Thanks for the tips! Could you or someone else explain exactly how to install these LED strips? Do I need to do a lot of routing or drilling, or can it be done with some basic DIY skills and standard tools? I’m especially interested in installing the power outlet without much hassle, but I’m not very experienced technically.
kaubi
29 Dec 2023 12:33
talha68 schrieb:
Can you or someone else explain exactly how to install such LED strips?
Gladly! Installing the light strips for Ikea PAX wardrobes is actually quite straightforward:
- The LED strips "OMLOPP" are battery-powered adhesive strips. You can stick them directly inside the door or cabinet body using the included adhesive tape. No drilling is needed. To replace the batteries, simply remove the strip.
- The "NÄVLINGE" LED strips also come with adhesive tape, but are designed for a fixed 12V connection via the supplied transformer. This requires running a cable to a power outlet. I often route the cable through the back panels of the cabinets, which usually already have holes or cutouts.
- Power strips are typically mounted with screws or hook-and-loop tape in a niche or on the inside of the cabinet. Note: For wiring, hiring an electrician is advisable, especially if new power outlets are installed inside the cabinet.
- It is not necessary to heavily mill or drill. With a cordless drill, drill, and some patience, this is quite manageable.
If you like, I can also put together a small step-by-step guide for you.
talha68
29 Dec 2023 16:07
kaubi schrieb:
If you like, I can put together a short step-by-step list for you.
Yes, that would be really helpful! If you also have any tips for laying the cables, I would be very grateful. That way I can plan my order better and ask the electrician more specifically.
