ᐅ Is it possible to connect Ikea Pax wardrobes across multiple rooms to create shared storage?
Created on: 1 Jun 2022 08:23
Fargla
Hello everyone, I have a question about the Ikea PAX system that has been on my mind for a while: Is it possible to connect or link multiple PAX wardrobes located in different rooms so that they function as a continuous storage space? I don’t only mean visually, but also in terms of usability—for example, whether it’s possible to create access as if they form one connected unit, or if there are practical solutions for such integrated use. I’m especially interested in whether the modular system can be flexibly combined across different rooms, so that instead of having completely separate furniture pieces, there is a seamless storage space that also makes sense in everyday use. Are there any experiences, tips for connection systems, or special constructions? Thanks for your insights!
To add: From a technical perspective, Ikea Pax wardrobe modules are all based on the same standard dimensions, meaning the width and height measurements are standardized and compatible. This allows several modules to be placed seamlessly next to each other and secured against tipping with connecting elements.
However, when used across multiple rooms, assembly and stability issues quickly arise. This is due to slight floor irregularities and varying wall heights or angles, which can affect the precise connection.
Additionally, for doorways or passages, care must be taken to ensure the furniture does not obstruct access or get damaged. Therefore, connections at room transitions should ideally remain detachable or easy to disassemble. For fixed, more solid connections, it is generally recommended to set up the furniture together in one large room.
Thank you all for the interesting discussion and your well-informed insights! The points about floor unevenness and stability make a lot of sense, and I will probably need to plan for each room individually after all.
I would still like to know: Are there any experiences with how well PAX wardrobes stand on floors that aren’t perfectly level? I have heard that spacer plates or leveling elements can be used, but I am unsure how this affects stability when multiple wardrobes are connected together. For example, I have different tiles and carpeted areas in the adjacent rooms, so this could be relevant.
Adjusting PAX cabinets on uneven or different floor surfaces is indeed an important issue. Ikea often provides small adjustable feet, but these only compensate for minor differences. If the floor unevenness or differing coverings (tiles, carpet, wood) are more pronounced, I recommend using additional spacer plates or adjustable furniture feet that can compensate for greater height variations.
It is important that all connections between the cabinets are designed to accommodate or at least tolerate small height differences to avoid creating tension in the system.
If this is not possible, especially with fixed connections between cabinets, material damage or functional problems with the doors may develop over time.
Therefore, if you want to connect multiple PAX cabinets, checking the floor beforehand is crucial. A uniform floor or professional leveling is advantageous in this case.
Hello, I would like to add that the practicality of connecting PAX wardrobes also depends on the room layout and the door width.
If the rooms are next to each other and, for example, there is a double door or an open passage, it is theoretically possible to create a continuous storage wall. In such cases, it is advisable to use sturdy connecting rails and screws, which Ikea provides for securing the wardrobes.
Alternatively, you can use matching panels and covers to minimize gaps and visually create the impression of a continuous system.
In cases where doors separate the wardrobes, a fixed connection is always problematic because it could affect the door's range of motion or cause pressure marks. Flexible connections or visual alignments without rigid links are better suited here.
If you have specific measurements or floor plans, we could look more closely at which options would work best.
Takutau schrieb:
If the rooms are adjacent and, for example, there is a double door or an open passage, it is theoretically possible to create a continuous storage wall.This is an important point. In such architectural situations, you can place PAX closets on both sides of the passage opening and create a connection using suitable panels or custom-made shelves. However, a secure attachment with brackets or connector plates might require some flexibility to compensate for uneven levels or slight misalignments.
If possible, I would recommend planning this transition zone carefully with precise measurements before purchasing. Quick adjustments after installation are limited due to the fixed dimensions of the PAX system.
It may also be useful to experiment with different floor heights using small prototypes before the full installation, for example by assembling modules in the living space to test how it looks and functions.
RonJarrett2 Jun 2022 12:14Fargla schrieb:
Are there any experiences on how well PAX wardrobes stand even on floors that are not completely level?I can confirm that the supplied adjustable feet only compensate for unevenness to a limited extent. Beyond that, it is advisable to use additional supports for height adjustment and stabilization. It is also best to use laser levels to align the wardrobes perfectly straight. When several wardrobes are rigidly connected, otherwise there is a risk of tilting movements that can cause damage over time.
In general, careful preparation is essential when installing on different types of flooring. Therefore, I would recommend using spacers or pads under individual wardrobes to prevent unwanted wobbling.
