Created on: 27 May 2019 10:48
goalkeeper
Domski
18 Dec 2019 22:49
Drywall construction for attaching a wall cabinet?
Double-layered: one layer of fine or coarse particleboard, followed by one layer of gypsum board. Fasten using 40mm (1 5/8 inch) or 50mm (2 inch) screws. Done.
Tina mit K18 Dec 2019 22:55
Precisely with hollow wall anchors. In our case, one did not fully expand because there wasn’t enough space. On the side, a different anchor needs to be used.
11ant19 Dec 2019 00:38
UpperEast schrieb:
However, in my opinion, lighting is very important for daily well-being and worth the money for professional advice.
However, "lighting design" has become a buzzword, and so far I have mostly come across lists of lamp models to buy. That feels more like a sales pitch than valuable consultation.
Wickie
19 Dec 2019 08:00
Lighting was a very… let’s say… sensitive topic for us. However, since I’m a professional, I know exactly what happens when the lighting isn’t right.
But regardless of whether you want to hire a lighting designer or not: I also have to know myself how I want the room to be lit later. I don’t have to satisfy any standards like DIN to have a certain light intensity—I need to feel comfortable.
I didn’t “approve” a single cable from my husband unless he could first tell me which fixture was going to be installed there and what it was for:
“Let’s just run a cable here and see what happens.”
“Show me the fixture that will go there.”
“No idea.”
“No idea—no cable.”
“… I like that fixture.”
“Okay, then we run a cable here, and we need one of those little ones over there, or that corner will be too dark.”
For every fixture—every cable. I think sometimes during the build, he probably wanted to hang me from one of those cables.
We selected fixtures that match the style of the house and our furnishings and that we liked, then cables were installed for them. There are very few recessed spotlights, mostly ambient lighting around the room. In the evening, when you’re sitting in front of the TV, you don’t want to feel like you’re in an office or hotel lobby. It should be cozy, but there’s no need for a battle of lumens. Table lamps, eliminating dark corners, maybe highlighting some paintings. But there also needs to be light when it’s necessary (cleaning or whatever), and so on.
Like the tip about vacuum cleaners when planning electrical outlets: imagine your daily routine.
How do I want it to look when I:
- Sit in front of the TV
- Sit with friends at the dining table
- Play board games at the dining table
- Cook
- Clean
- Read on the sofa? Knit or crochet while watching TV?
- Take a bath? Also: when I need light for plucking eyebrows
- Leave the house and put on my jacket and shoes in the hallway
- Come home (switched outlets!)
Looking back now, I did everything right!
There should be a lighting task to be fulfilled, and you need to be aware of it beforehand. What do I want to achieve there?
Once the cable is installed, you have to find a fixture that fits PERFECTLY there. Much harder, and especially for non-professionals, even more challenging!
My favorite phrase became my favorite phrase even more during the building phase:
If you don’t know what you want, you get what you don’t want!
What do I want to do there? Which fixture do I like? Can the fixture do what I need it to do (and can I afford it)?
YES: plan the cable, buy the fixture.
NO: keep searching!
Sounds tedious, and it is, but it’s worth it.
Winniefred19 Dec 2019 08:11
We didn’t overcomplicate it. Some of our lamps came from our old apartment, and we bought the others after moving in. We ran cables wherever they are usually needed. Furniture gets rearranged or replaced anyway. Of course, we took workspaces into account. But otherwise, we simply installed cables where they made sense. In every room, we also have wall lights for softer evening illumination. We were quite pragmatic here and probably didn’t have high expectations. As long as I can see well enough when I turn on the light, I consider it done right.
apokolok
19 Dec 2019 08:16
Regarding the wall cabinet:
Tell the drywall installer to use two layers of OSB and then drywall on top, as a vanity has quite a bit of weight. That way, you can simply use proper wood screws without pre-drilling.
