ᐅ Attaching a Kallax Door Handle Without Drilling – Any Tips?
Created on: 25 Jul 2020 08:37
tarneo
Hello everyone, I bought a Kallax shelf unit from Ikea and would like to add doors with handles. However, I don’t want to drill any holes because I don’t want to damage the shelf and might want to use it differently later on. Has anyone successfully installed Kallax door handles without drilling? What tricks or materials can be used to make sure the handles hold securely and firmly without relying on traditional screws? I’m looking forward to your tips and experiences!
V
volker0
25 Jul 2020 14:38
In the case of Kallax, the door material is often not very thick. Therefore, I would recommend clamp handles that you attach to the outside edge of the door – no drilling, no residue.
Muso4
25 Jul 2020 16:01
Parbo schrieb:
But I would like to know: How much weight are the handles expected to bear?
Why all the caution? Sure, you don’t want to damage the shelf. But let’s be honest: Who installs a handle if they don’t expect to use it daily? Taking the time to glue handles that will eventually fall off is just wasted effort. It’s better to drill once and be done — that way it will hold securely.
This fear of drilling is often exaggerated. I’m not saying to hammer away recklessly, but sometimes a bit more confidence is just what’s needed.
tarneo
26 Jul 2020 09:14
Muso4 schrieb:
This fear of drilling is often exaggerated.\
Thanks for the insight, I understand the point! For me, it’s more about the idea that the shelf might be sold or used differently later on. So I’d prefer to minimize any damage.
The handles will be used regularly, I open the doors quite often. The doors themselves are about 16 mm (5/8 inch) thick with a fairly smooth surface. Parbo, your question about that was great—so there will definitely be some stress on them. What do you think: Are VHB tapes really sufficient for daily use? Or would you recommend combining them with, for example, framed clips that can be installed without drilling?
Parbo
26 Jul 2020 10:03
tarneo schrieb:
What do you think: Are VHB adhesive tapes really sufficient for daily use?
Thank you for the detailed answer!
With 16mm (0.63 inch) thick doors and a smooth surface, you are in a good position for adhesive solutions. The VHB tape can definitely withstand dynamic forces, provided that:
a) You clean the surface very thoroughly (use alcohol, and if painted, possibly fine sandpaper).
b) Your handle itself is not too heavy or too large (the larger it is, the more leverage acts on the adhesive bond).
A combination with small clamps on the back can provide additional stability and reduce tension on the adhesive.
Details:
- Cleaning: Very important! Even dust or small soap residues can temporarily reduce adhesion strength.
- Applying: Press firmly for about half an hour, then avoid immediate use. Allow 12–24 hours of curing time for the adhesive to fully set.
Feel free to ask if you can describe the type of handle, so I can give you better material recommendations.
LAURE-TA
26 Jul 2020 11:22
Parbo schrieb:
A combination with small clips on the back can provide additional stability
I completely agree. I would like to add the following:
If you plan to remove the handle and door later, make sure the adhesive points can be removed cleanly. VHB adhesive tapes can usually be loosened with some heat (hairdryer), unlike foam adhesives that need to be scraped off.
If you’re willing to experiment, you can attach small metal brackets on the inside without drilling, using strong adhesive pads, to mechanically secure the handle. This creates a sort of hybrid mounting and significantly increases durability.
