ᐅ Attaching a Kallax Door Handle Without Drilling – Any Tips?
Created on: 25 Jul 2020 08:37
tarneo
tarneo
25 Jul 2020 08:37
Hello everyone, I bought a Kallax shelf unit from Ikea and would like to add doors with handles. However, I don’t want to drill any holes because I don’t want to damage the shelf and might want to use it differently later on. Has anyone successfully installed Kallax door handles without drilling? What tricks or materials can be used to make sure the handles hold securely and firmly without relying on traditional screws? I’m looking forward to your tips and experiences!
Parbo
25 Jul 2020 09:02
Hello tarneo,
Your question is very interesting, as many people underestimate the stability of Kallax doors without drilling. Basically, the feasibility greatly depends on the type of handle and the door material – whether plastic, MDF, or wood.
1. Adhesive tapes designed for heavy loads, such as 3M VHB, can often hold surprisingly well, especially if the surface is clean, grease-free, and smooth.
2. Another trick is securing the handle with clamp rails, which are attached to the edge of the shelving unit and allow you to fix the handle without drilling holes.
3. Magnetic solutions can also work if the doors are magnetic or have been modified accordingly.
However, I would like to know: How much weight will the handles bear (e.g., opening regular cabinet doors, frequent use) and how thick are the doors? This way, more accurate recommendations can be made.
LAURE-TA
25 Jul 2020 09:45
Hello!
I’d like to share my experience, as I have completed similar projects several times.
For attaching Kallax door handles without drilling, I recommend a three-step approach:
1. Choosing the right adhesive solution: 3M VHB double-sided tape works great if the door surface is smooth and clean. Make sure to apply it over the entire contact area to ensure a strong bond.
2. Preparing the surface: Clean the door with alcohol or a suitable cleaner to remove any dust or grease that might affect the adhesive performance.
3. Be cautious with the load: Depending on how often you open the doors, adhesive solutions can weaken over time. If you want to move the shelf, I suggest carefully peeling off the handles and replacing the adhesive if necessary.
An alternative option is self-adhesive clamp handles for cabinet doors that can be installed without tools. While I haven’t tried these on Kallax units myself, I’ve heard good feedback from others.
Good luck!
Raymond
25 Jul 2020 10:12
Hello tarneo,
I just wanted to add to what others have already said: It is important that the handles match the type of fastening – some are designed for screws, while others are made specifically for adhesive or clamps.
If you have standard Kallax door handles that require drilling, you might consider replacing them with flexible silicone or plastic handles that can be mounted with clips without screws.
For our Kallax doors, I alternatively secured the handles on the inside using narrow cable ties. It works surprisingly well as long as it’s not visible and there are no sharp edges.
So, if you don’t want to fully glue the door, such improvised fastening methods are an inexpensive option.
fepau
25 Jul 2020 13:27
Hey tarneo, it’s great that you’re thinking about how to enhance the shelf nicely without drilling! 🙂
I recently had very good experience with strong adhesive pads on a similar project. Just place two pads side by side – that gives more holding power than using just one. It’s really important to prepare the bonding surface well beforehand and then apply pressure for about 24 hours. I also initially weighted the handles with a few heavy books for the first few hours.
There are also flexible clamp-style handles you can try out at a hardware store.
Good luck, you can do it! 🙂
Celia
25 Jul 2020 14:05
If you don’t want to drill, I simply recommend 3M VHB double-sided tape. It has held perfectly on my Kallax for months. Important: make sure the surface is grease-free. Otherwise, it will slip off.
