ᐅ Is It Practical to Fix the BILLY Shelf Back Panel with Adhesive?
Created on: 2 Jul 2023 10:17
fukeme
I am planning to assemble a Billy bookshelf, and I wonder whether it makes sense to attach the back panel with glue instead of just using the usual small nails. I understand that the back panel mainly provides stability, but I am curious if using glue offers any advantages, such as increased stability or a cleaner appearance without visible nails, and whether there might be long-term issues with adjustments or disassembly.
Has anyone had experience with whether fixing the back panel with glue is advisable or if it could be counterproductive? If you would recommend glue, which types are suitable?
Thanks in advance for your opinions and tips!
Hello fukeme,
I would like to elaborate a bit more on the considerations. Your assumption that a combination of adhesive and nails is better than nails alone is basically correct. Especially with varying loads and potential twisting, the adhesive ensures a more even distribution of forces.
Regarding durability, I can add the following: A high-quality, flexible wood glue remains elastic enough over the years to absorb minor movements without causing cracks. However, you should definitely make sure to apply the glue as sparingly as possible but over the entire surface to avoid creating a thick glue layer that could become brittle.
It is also important to gently press the back panel after applying the glue and allow sufficient drying time—at least 24 hours. During this period, the shelf must not be loaded.
If you still have concerns, an alternative would be to fasten the back panel with smaller nails and additionally apply shrink wrap film (!) on the backside, so the back panel is slightly tensioned and vibrations are reduced.
Conclusion: For your project, using wood glue is indeed sensible, provided you assemble carefully and allow the back panel to dry undisturbed.
Gafiel schrieb:
Using wood glue is definitely useful, as long as you apply it carefully.I agree, but please make sure to apply it correctly. Dabbling glue won’t help; it needs to be spread evenly.
gregto schrieb:
The bonding surfaces should be clean, grease-free, and slightly roughenedThis is a crucial point. If the back panel and the cabinet body are not properly prepared, even the best wood glue will hardly stick. Using fine sandpaper, grit 180, on the surfaces helps a lot.
Procedure:
1. Apply glue thinly and evenly.
2. Position and align the back panel first, then secure it with clamps or clips.
3. Immediately wipe off any excess glue with a damp cloth.
4. Let it rest for at least 24 hours, preferably at room temperature and low humidity.
A small tip: If you want to disassemble the shelf later, you can place thin strips of paper (e.g., newspaper) along the edges as a separating layer before gluing. This way, it will still be stable enough for everyday use but can be taken apart when needed.
fukeme schrieb:
The combination of adhesive plus nails on the durability of the back panel?A note on the load-bearing capacity of the back panel: The thin hardboard is not a structural component meant to carry loads directly; it serves for stiffening. Nails provide the mechanical connection, while the adhesive allows for load distribution over larger areas.
I recommend using quality nails (finish nails) and applying the adhesive sparingly to prevent moisture from penetrating the back panel. Moisture would be harmful, especially for MDF or hardboard panels.
If you plan to move the shelf later, you can sometimes attach the back panel with nails only and apply adhesive only at certain points. This way, you can achieve a combination that is stable but still relatively easy to remove later.
Thank you for the detailed and very helpful posts!
I’m planning to assemble the shelf like this: fully glue the back panel with a thin layer of wood glue and then additionally fix it with small nails. This way, I get stability and the look without visible protruding nails.
The tips on surface preparation, sanding, and the curing time are really important – I will follow them carefully.
If I may ask an additional question to the experienced DIYers here: Which wood glue do you specifically recommend for bonding the thin BILLY back panel? Should I use waterproof glue or is a standard D3 wood glue sufficient?
Thanks a lot!
Thanks a lot!
