Created on: 31 Jan 2020 13:29
Shiny86
Slope yes
Site coverage ratio?
Floor area ratio?
Boundary development?
Number of parking spaces 2
Number of floors 2
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
What don’t you like? Why?
Good: large living area
  • Where could it still be optimized? Would you recommend different window dimensions or sill heights?
  • What do you think is poor or what would you do differently?
  • A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
  • Is the hallway on the ground floor too narrow?
  • Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
  • Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
  • Is the kitchen size sufficient for a nice kitchen with an island?
Floor plan of a single-family house: living/dining area, kitchen, hallway, storage room, cloakroom, WC.
Floor plan of a family home: CHILD 1, CHILD 2, PARENTS, WALK-IN CLOSET, BATHROOM, SHOWER/BATHROOM, HALLWAY.
Architectural drawing: two-story residential house with garage; southwest and northeast views.
Two facade views of a house: northwest and southeast with roof, windows, terrace, and garage.
11ant4 Apr 2020 13:18
Shiny86 schrieb:
A 3.30m x 4m (10.8 ft x 13.1 ft) chill-out area is definitely not too small.
Heureka! – I’m so glad to see this! – she didn’t say 330 x 400 cm (130 x 157 inches)! – I am a very happy 11ant, woohoo!
Shiny86
4 Apr 2020 13:26
Eureka! – I can’t believe I’m still alive to see this! – she didn’t say 330 x 400 cm (130 x 157 inches)! – I am an overjoyed 11ant, yahoo!
Well, the day before yesterday I would have said 3.32 m x 4.07 m (131 x 160 inches).
If you change the staircase, you arrive earlier in the hallway on the upper floor and can get to the bathroom sooner. This leads me to the following idea.
Is it practical, or does it look awkward? Imagine a stylish shelf or cabinet for a washing machine and dryer stacked on top of each other.
Technical floor plan of a room with walls, door, furniture, and measurements.
kaho6744 Apr 2020 14:08
Which one is the intended initial design now? The one from #1?
Shiny86
4 Apr 2020 15:01
kaho674 schrieb:
Which initial draft is still being referred to? The one from #1?
No. This one. I would do it like this now. And place the washing machine at the height as previously drawn.
Floor plan of a residential house with hallway, kitchen, guest room, utility room, WC, and stairs.
Floor plan of the upper floor: two children's rooms, master bedroom, corridor, dressing room, bathroom, shower room.
Shiny86
5 Apr 2020 13:38
How wide is a typical open passageway without a door lintel from the hallway to the living area? Do you find that practical?
If you decide you want a door, can you easily reduce the width of the opening using drywall construction and install a door afterwards?
11ant5 Apr 2020 15:15
Shiny86 schrieb:
How wide is an open passage without a lintel from the hallway to the living area typically? Do you find that practical?
Since this is a load-bearing wall, I would not omit the door lintel but only the door frame (casing). I think the size as shown with the door included is already appropriate.
