ᐅ Kallax as a Base for a Washing Machine – Recommendation or Risk?
Created on: 11 Aug 2020 15:03
pukenHello everyone,
I am planning to place my washing machine on an IKEA Kallax shelf unit to gain some storage space and raise the machine slightly higher. My question is: Is it generally advisable or rather risky to use a Kallax unit as a base for a washing machine?
I understand that a washing machine vibrates during the spin cycle and needs to stand on a stable surface. The Kallax is solid but made of wood-based material and not necessarily designed for such weight or movement.
Does anyone have experience with this? Are there specific reinforcements available, or is it generally problematic, for example due to structural stability or moisture?
I look forward to your opinions and experiences!
Hello puken,
Basically, the Kallax shelf is not designed to support dynamic loads like a washing machine during spinning. The shelf lacks reinforcement against lateral movement, and the wooden panel may swell over time due to moisture.
Tip:
1. If you absolutely want to use it, secure the Kallax with a sturdy, water-resistant plywood board as a top base.
2. Reinforce the structure further with brackets and screwed supports on the sides.
3. Check the floor surface, as Kallax often stands on small feet that need to distribute the load.
Conclusion: A solid base or a dedicated laundry cabinet is a better choice because safety comes first. Otherwise, you risk damage to both the furniture and the machine.
Tip:
Hello puken,
I’d like to explain in more detail what to consider when using a Kallax shelf as a base for a washing machine.
1. Load Capacity: Kallax is made of particleboard and designed for light to medium loads. The weight of a washing machine with water is quite high – typically between 60 and 80 kg (132 and 176 lbs).
2. Dynamic Load: During spinning, the machine produces strong vibrations. These cause lateral forces that can shift the shelf from its resting position.
3. Moisture: Laundry rooms often have elevated humidity. The particleboard in the Kallax can swell and warp.
A recommendation: If you really want to use Kallax, place a sturdy plywood sheet on top and secure it firmly. Additionally, the Kallax shelf should stand on a level, solid floor without wobbling. Rubber feet or anti-vibration mats under the washing machine can help reduce movement.
Overall, I would advise against using Kallax as a washing machine base, as it does not provide optimal safety or durability.
