ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
  • Where could it still be optimized? Would you recommend different window dimensions or sill heights?
  • What do you think is poor or what would you do differently?
  • A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
  • Is the hallway on the ground floor too narrow?
  • Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
  • Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
  • Is the kitchen size sufficient for a nice kitchen with an island?
What do you think about the floor plans?
Floor plan of a single-family house: living/dining area, kitchen, hallway, storage room, cloakroom, WC.
Floor plan of a family home: CHILD 1, CHILD 2, PARENTS, WALK-IN CLOSET, BATHROOM, SHOWER/BATHROOM, HALLWAY.
Architectural drawing: two-story residential house with garage; southwest and northeast views.
Two facade views of a house: northwest and southeast with roof, windows, terrace, and garage.
3 Apr 2020 00:05
I would then swap the living room and kitchen. Who is interested in this garage? A shrub in front and a flexible seating area. The space will be nicely sheltered from the wind.
Shiny86
3 Apr 2020 00:10
I would swap the living room and kitchen. Who cares about the garage? Put a shrub in front and create a flexible seating area. The space will be nicely sheltered from the wind.
Do you mean keeping the latest version with the TV corner as is and just mirroring it?
Unfortunately, you’re not allowed to build a terrace because it’s only 3–4 meters (10–13 feet) from the neighboring property. If I’m correctly informed, you need to keep about 2.5 meters (8 feet) distance between a terrace and the neighbor.
Shiny86
3 Apr 2020 00:16
Are you insisting on having three guesses?
It's probably more of a case of making things worse by trying to improve them, if you ask me. I’ll just go to the utility room to do the laundry. There are worse things. I can manage to get the laundry done.
Thanks for your solution. That’s why I arranged the bathrooms on the upper floor that way. This allows for swapping the living room location without needing changes to the drainage or creating wall stubs. And there’s no protrusion in the guest room.
What annoys me, though, is the cloakroom situation. Would it look odd to carve out a niche for a cloakroom from the guest room? Or would that ruin the room? I’ve already taken some space from the utility room for the toilet...
11ant3 Apr 2020 00:30
Shiny86 schrieb:
Thank you for your solution.
However, you don’t seem to fully understand, because:
Shiny86 schrieb:
That’s why I arranged the bathrooms on the upper floor that way. This allows swapping the living rooms without having to change the drainage or cut into walls. And there’s no recess in the guest room.
But the wardrobe situation annoys me.
... in plan version #402, the downpipe doesn’t go down through the utility room, but through the wardrobe (good grief, throw some brains from the sky), so I can totally understand the dissatisfaction!
Shiny86
3 Apr 2020 01:58
What do you want?
I think we are talking past each other.
Currently, I don’t have a wardrobe anywhere.
The plans you posted, I only uploaded them as a possible solution to achieve the living room/kitchen swap. Specifically, by paying attention to the rooms and no longer planning a living room under a bathroom. I don’t care if pipes run through the utility room or a wardrobe. They can even go through a corner of the guest room. But not next to my couch.
3 Apr 2020 07:50
Shiny86 schrieb:
Unfortunately, you are not allowed to build a terrace.
A flexible seating area is not the same as a terrace.
A flexible seating area could be, for example, a small table with two chairs that can be rearranged as needed. You can place it on grass or on creative surfaces such as a small gravel bed or a mulch base. Beach sand is also suitable.
