ᐅ Preliminary floor plan design for a 220 m² single-family house
Created on: 20 Jun 2017 22:41
R.Hotzenplotz
Hello!
We have already gone through several plans with our architect and I think we are almost there, about to start the detailed planning phase. Before that, I’m looking forward to getting feedback from other users.
Development plan/restrictions: §34 – two full stories
Plot size: 1,085m² (1,1679 yd²)
Basement, floors – 2 full stories plus partial basement
Number of people, ages – 3 people (37, 34, 1, second child planned)
Space requirements on ground floor and upper floor – the requirement was that bedrooms and the study should be about 17m² (183 ft²) each; the entire house should be approximately 220m² (2,368 ft²)
Office: family use
Guests per year: 1
Open or closed architecture: closed
Traditional or modern design: modern
Open kitchen, kitchen island – no open kitchen, but yes to a kitchen island
Number of dining seats – 6
Fireplace – yes
Music/stereo wall – TV wall
Balcony, roof terrace – balcony
Garage, carport – large garage
Additional wishes/special features/daily routines, preferably with reasons why certain things should or should not be included – everyone should be able to sleep as undisturbed as possible in their bedrooms, even if other family members are awake. The husband is sometimes up as early as 4 a.m. Otherwise, watching TV in the evening should be possible without disturbing those sleeping upstairs.
Who created the design:
- Architect (freelancer for a general contractor)
What do you like most? Why?
The upper floor with well-sized rooms and the location of the rooms exactly where they should be (only the washroom area we would still like to move to the outer right corner so that you don’t have to pass it every time you use the toilet). On the ground floor, the access through an airlock, the kitchen, and the dining area with the study next to it are especially liked.
Also appreciated is that after adjustments, the study now faces the garden instead of the street.
What don’t you like? Why?
We originally wanted the distance from wall to wall where the sofa and TV stand is to be about 6.40m (21 ft) (large screen & surround system), but so far only 5.69m (19 ft) has been realized.
Laundry room as described.
Kitchen larger in square meters than needed; the approx. 3m² (32 ft²) could theoretically be used well in the living area.
720,000 euros (including construction incidentals)
Personal price limit for the house, including equipment:
800,000 euros
Preferred heating technology:
Gas
If you have to give up on something, which details/features can you do without?
- Can do without:
Technical systems like controlled residential ventilation
- Cannot do without:
Space (except for the kitchen)
Why is the design the way it is now? For example:
Is this a standard design from the planner?
The architect has largely implemented our wishes; the only issue is the living room situation.
Patient, quick to implement, has already gotten to know us well.
No negative points.
Do you notice any other points that might not fit or that we should consider, which we might have overlooked?
In the basement, the room currently labeled as home cinema might possibly be used as one medium- to long-term. For the foreseeable future, it will be a storage room.
Office: family use
Guests per year: 1
Fireplace – yes
800,000 euros
Gas
- Can do without:
No negative points.
winnetou7816 Aug 2017 13:40Just checked quickly, no, it’s not available online, sorry.
It’s rather small.
It’s rather small.
R.Hotzenplotz16 Aug 2017 14:16I am reviewing the following carefully once again: the website of "Klinker."
In combination with a brick veneer, I believe that calcium silicate blocks are becoming interesting again as a wall material because they provide excellent sound insulation, and their poor thermal insulation properties are partially compensated by the brick cladding.
Since the A4 highway is not far away and we are not sure how it performs with unfavorable wind conditions, we are not completely convinced by aerated concrete / Poroton.
R.Hotzenplotz schrieb:
My wife also found the brick on the second picture acceptable, but I think it looks a bit outdated. The one in the right picture has a rougher texture, while the brick on the left picture is more ceramic-like in surface – in my opinion, that’s somewhat like comparing apples and oranges.
Our living room will be painted lavender. That doesn’t really match the redder brick. Also, since the overall Bauhaus style is dominated by the hipped roof, I would go with the smoother brick. With the rougher, redder one, the hipped roof tends to dominate too much, making the lavender paint a bold choice. What type of window frames are planned?
In combination with a brick cladding, I believe calcium silicate stone becomes interesting again as a wall material because it offers excellent sound insulation, and the negative insulation properties are partially compensated by the brick cladding. You’re thinking again in areas best left to others. I have pointed out (probably in other threads) that the “stone” and the “installer” form a system that should not be mixed unfamiliar. If your builder specializes in red brick masonry, don’t push them to build with white bricks.
R.Hotzenplotz17 Aug 2017 00:2811ant schrieb:
What window material is planned?We still want to discuss that with the builder. I think it will probably be standard PVC windows.
If your builder specializes in bricklaying, don’t force him to use white bricks.He builds whatever is ordered. So far, he hasn’t tried to steer things in any particular direction.
With plastic windows, I tend even more clearly towards the smoother brick.
If the builder is equally experienced with both red and white bricks, that’s fine – but I wouldn’t want to “retrain” someone who has a strong preference.
