ᐅ Why is one side of my IKEA PLATSA shelving unit taller than the other?
Created on: 21 Dec 2019 11:22
koenraad41K
koenraad4121 Dec 2019 11:22Hello everyone,
I recently assembled an IKEA Platsa shelving unit and noticed that one side stands higher than the other. The difference isn’t huge, but it’s noticeable enough to bother me, and leveling it doesn’t work perfectly. My question is: why might my IKEA Platsa unit be higher on one side than the other, even though I followed the assembly instructions?
I set up the unit on a fairly level floor, and the individual modules all seem to be correctly put together, yet one side is still higher. Are there common causes like uneven floors, incorrect installation of the feet, or even manufacturing defects with Platsa?
Looking forward to your experiences and advice. Thanks in advance!
Hello koenraad41,
First of all, thank you for your clear question; it makes it much easier to provide an answer. The issue of an IKEA PLATSA shelf being higher on one side often comes down to a few common causes. I’ll break it down into a few steps:
- Checking the floor surface: Even if the floor looks level, small uneven spots can be hard to detect. It’s best to use a spirit level or a small laser level to check the floor around the shelf.
- Feet and leveling screws: The PLATSA system features adjustable feet, which are often not fully adjusted during assembly. Sometimes a screw isn’t turned all the way down, affecting the height. Check whether all leveling feet are screwed down completely or if they are adjusted to balance the shelf.
- Misalignment or incorrect assembly: If the units are not connected at perfect right angles, it can cause a height difference. This often happens when side connections are not fully flush. In such cases, it helps to loosen the connection and realign it firmly.
- Material tolerances: IKEA products are generally high quality, but for affordable furniture, slight manufacturing variations can occur. However, these should typically be within a few millimeters.
If you have checked all the points above and the problem still persists, it’s worth taking a close look at the instructions and especially the feet. Sometimes it helps to completely disassemble the shelves and reassemble the modules precisely.
In summary: The most likely cause is either a slightly uneven floor or incorrect adjustment of the leveling feet. If you want, I can give you some additional tips on what to particularly watch out for when adjusting them.
fugolo schrieb:
The most likely cause is either a slightly uneven floor or incorrect adjustment of the leveling feet.Exactly. Check the leveling feet and the floor leveling. That's usually where the problem lies.
koenraad41 schrieb:
The difference isn’t huge, but it’s noticeable enough to bother me, and leveling it doesn’t work perfectly.Ah, the classic furniture puzzle! 😄 The PLATSA shelving unit is flexible and practical, but sometimes these small height inconsistencies creep in. Usually, a bit of patience and a spirit level can fix it. If that’s not enough, placing a thin felt pad under the feet on the lower side can help. Sure, it’s not exactly ‘original IKEA,’ but the main thing is that your shelf looks solid and level. And if you move someday, you can just take the felt pads with you! 😉
Don’t get discouraged—assembling furniture can sometimes feel like crafting with a touch of magic.
Based on my experience with the IKEA PLATSA system and various installations, I recommend the following systematic approach:
- Use a precise level to check both the floor and the shelving units.
- Verify that the module connections are properly screwed together. Even slight misalignment can cause height differences.
- Check the adjustable feet. PLATSA has screw feet with adjustable length to compensate for minor unevenness in the floor.
- Ensure that the individual modules lie flat against each other. A slight gap at the edges can affect overall stability.
If none of these measures lead to a satisfactory solution, consider replacing the feet. In this case, contacting IKEA regarding goodwill options is advisable.
Finally, it should be noted that manufacturing tolerances can be minor but are rarely noticeably significant. Documented complaints are recommended in case of clearly visible installation deviations.
