I am currently considering expanding my Ikea Platsa shelving units and wanted to ask: Is it possible to easily extend Ikea Platsa shelves?
Specifically, I mean whether the existing modules can be connected without difficulty, for example, to turn a single row of shelves into a longer one without compromising stability or appearance.
I plan to install the system against a wall and would like to know if Ikea offers any official options for this or if it mainly relies on DIY solutions. It would also be important to get advice on possible connectors, load capacity after extension, and whether reinforcements are needed when extending the units.
Thanks in advance for your experiences and tips!
I’m sharing a brief guide on extending Platsa units:
- The standard connector pieces come with the packages but are usually intended for a single connection.
- For multiple extensions, you may need to purchase additional connector sets, especially the "connectors for side panels."
- Important: All modules should be secured to the wall using the supplied safety fittings.
- Regarding the overall length: The longer the system, the more wall mounts or reinforcements you should plan for.
Common mistakes:
- Modules only loosely assembled and not fixed to the wall quickly become unstable.
- Incorrect use of connectors or using too few can cause the shelving to wobble under load.
Conclusion: Extensions work very well, but you need to do it carefully and, if necessary, obtain additional connector sets.
Common mistakes:
As an addition:
Ikea specifies in the technical data of the Platsa series that the modules can be connected modularly and that the load capacity is maintained if the connecting elements are installed correctly.
The maximum load per module is approximately 30 kg (66 lbs) evenly distributed.
Wall mounting is mandatory to prevent tipping.
The connection is made using metal connectors that snap into the side panels – these are usually included, but for larger extensions, it is advisable to check with the Ikea store or order connector sets online.
An extension in the sense of linking multiple modules together is therefore planned, but a single segment does not automatically bear the load of other modules.
warrenka572 Mar 2023 12:18I would like to briefly share my experience here: I had serious doubts for a long time about whether Platsa shelves can simply be extended, because I was worried that the system would become unstable and look unattractive.
In practice, however, it works well if you carefully obtain and install the connectors and wall anchors.
As Friedrich already mentioned, I would say: It’s better to use more wall brackets rather than too few. This provides a sense of security and also looks neat.
warrenka57 schrieb:
I had serious doubts for a long time about whether Platsa shelves can simply be extended because I was afraid the system would become unstable and look unpleasant.This concern is understandable and, to some extent, justified.
If the modules are not connected properly, small gaps or slight misalignments can occur between them.
To prevent this, you should:
- align the modules precisely
- insert all connecting pieces correctly
- ensure the wall attachment is properly secured
Then, a simple extension will be both visually seamless and stable.
Thanks to everyone for the helpful advice!
I have one last question: Are there any technical limits regarding the number of modules? In other words, at what point does it become either too unstable or technically impractical to continue extending?
Also, what about the option to add side panels or covers to an extended shelving unit to make it look more enclosed?
