ᐅ How can I retrofit or replace Ikea PLATSA doors?
Created on: 17 Jul 2023 09:12
rayan
rayan
17 Jul 2023 09:12
Hello everyone, I currently have an Ikea Platsa shelving unit without doors, but I would like to retrofit doors or replace the existing ones if that makes more sense. My specific question is: How can I add or replace Ikea PLATSA doors without dismantling the entire system? Are there compatible doors from Ikea or third-party suppliers, and how exactly does the installation work technically—for example, attachment points, hinges, and dimensions? I want to make sure the doors are securely mounted and look good. I am also interested in whether there are alternative, perhaps more flexible solutions to attach or swap doors. Thanks in advance for your advice!
KAUDRA62
17 Jul 2023 09:45
Hey rayan, great question! PLATSA is really a flexible system, and with a bit of creativity, you can do quite a lot 😄. Basically, Ikea offers matching doors for PLATSA in various styles – from simple to mirrored. The doors usually come with clip-on hinges that attach easily to the pre-drilled holes. If your shelf doesn’t have holes, it gets a bit tricky, but you can use things like flat brackets or clamp profiles to fix the doors anyway. Third-party options exist, but you need to pay close attention to measurements and hinge positions, otherwise it won’t work. Important: When retrofitting, you should hold the doors in place beforehand to make sure they close well and don’t rub. If you want, I can also share some photos and measurements from my PLATSA to give you a better idea!
KLO-KA
17 Jul 2023 10:07
Just a quick note: IKEA PLATSA doors only fit the pre-punched rows of holes. You need the appropriate dowels and hinges that IKEA supplies. Third-party doors often do not match the hole alignment exactly, so it's better to use original doors or take your own measurements and have custom doors made.
Ethan
17 Jul 2023 12:33
Hello rayan, I’m familiar with this – retrofitting PLATSA doors is doable with some patience. First, you should determine the exact type of your PLATSA shelving unit (width, height, depth), as the doors are specifically designed to fit these dimensions. The hinges are attached to pre-drilled holes on the side panels. If your unit doesn’t have these, it usually means the holes are missing and you’ll need to drill them yourself or find an alternative way to fix the hinges—just be careful to maintain the stability of the unit. Other options include sliding doors or folding doors offered by IKEA for PLATSA. If you want to replace doors, you can simply remove the old ones and install new doors with the same measurements. For third-party doors, I recommend measuring carefully and comparing the hole spacing, otherwise you won’t be able to use the hinges. If you like, I can write you a step-by-step guide on how to retrofit the doors.
TRADI
17 Jul 2023 14:09
Hello everyone, I’d like to pick up on this topic because I retrofitted PLATSA doors myself some time ago. It’s important to know that these doors are actually designed for the modular system – meaning there are doors cut to size for each PLATSA cabinet body, including the appropriate fittings. So you can simply buy a suitable door set from Ikea and attach it using the existing hinges and dowels.
For retrofitting, the key point is what type of construction your cabinet has – whether it has open shelves or pre-drilled side panels. The doors are typically attached with two hinges that hook into the cabinet’s side panels. If your cabinet doesn’t have holes, you either need to drill or use alternative solutions like clamp profiles.
Personally, I’ve had good experience with self-adhesive hinge plates when you want to avoid drilling. The only downside is that the doors might not hang quite as securely, but that depends on the weight. Otherwise, retrofitting original PLATSA doors is relatively straightforward.
blapau
17 Jul 2023 16:21
As an addition: If you want to replace the doors, be sure to check the exact depth and height of your PLATSA module before purchasing – the doors are cut to within a few millimeters and vary depending on the model. A common mistake is ordering doors that do not fit in size or hinge hole positions. If you have had the shelf for a longer time, you should also verify whether it is an older version, as some dimensions have changed slightly over time. For retrofitting: Installation is done using the original metal plates (hinges are screwed into the side panels) – if there are no holes or you are unsure, adapters or alternative hinges can be a solution, although this may compromise stability and appearance.
