ᐅ Why does my BILLY bookshelf wobble even though it is secured to the wall in multiple places?
Created on: 16 May 2018 09:12
JANINESAU
Hello everyone, I have a Billy bookcase from IKEA at home that still wobbles despite being fastened to the wall multiple times. I have securely mounted the shelf to the wall using the original angle brackets, fixing it in at least three places. All screws are tight, and the wall plugs are suitable for the wall material (concrete). Still, I notice some wobbling even with light pressure and during normal use. The wall is even, and I followed the assembly instructions step by step.
My question is: Why does my Billy bookcase wobble despite multiple wall fixings? Where could the problem be if all fastenings appear to be correctly installed and the wall seems stable? I look forward to your assessments and possible solutions!
JANINESAU16 May 2018 11:29Thank you for your responses so far!
@janeo: The shelf itself looks fine, no visible warping, and nothing is twisted inside either. The screws were installed using a cordless screwdriver until they were tight. The anchors are Fischer SXR 10x50, designed for concrete walls, so they should be suitable.
@Joshbe: The walls are plumb; I checked with a spirit level and a straightedge. I also double-checked the screws, and they are secure.
@Far34 and @Sinzar: The shelf stands on a smooth laminate floor but has no floor anchors or other fixings at the bottom. This could have an effect, but according to the IKEA assembly instructions, only wall brackets are actually required.
Is there a way to stabilize the structure afterward to prevent wobbling without having to completely modify the shelf?
Interesting point:
This could mean that the overturning moment is not fully counteracted due to tolerances in the floor and the wall attachment. Have you tried gently rocking the shelf to see when the fixings start to bear load? Sometimes small spacers or wedges can help improve the load distribution.
JANINESAU schrieb:
The shelf is standing on a smooth laminate floor but doesn’t have any floor screws or other fixings at the bottom.
luAlbert116 May 2018 12:50I wonder if the general trust in IKEA’s assembly instructions is overrated. The Billy shelf is an affordable unit, not a high-end bookcase. Its design is intended to work with low-cost materials and basic fasteners—but only to a certain extent. Wobbling even after wall mounting? Maybe that indicates you can’t expect too much stability from this kind of furniture.
I would consider alternative solutions rather than relying solely on the assembly, as much as I like IKEA.
JANINESAU16 May 2018 14:07@luAlbert1: I don’t think your assessment is entirely accurate; the shelf does serve its purpose, but that wobbling is annoying. These are modular units, and they should definitely be stable. That’s why I want to find out exactly what matters here.
@janeo: I just tried it again and noticed that the wobbling gets worse when I move the shelf a few millimeters (inches) sideways along the bottom. It feels like the shelf is held against the wall but has a little play at the bottom.
What kind of spacers do you mean specifically? Plates, strips? And where is the best place to attach them to effectively reduce the wobbling?
Correct – spacers are often thin plastic or wooden strips that can be attached to the bottom back of the shelf to help press it more firmly against the wall while also optimizing contact with the floor. Nothing at the front of the shelf should interrupt floor contact, as this would affect stability.
Non-slip mats or pads can also help reduce wobbling, especially on smooth floors.
